3689495698?profile=original
I came across this while researching wireless solutions and seems very possible to create a long range WiFi connection between the GCS and aircraft using an onboard micro computer.
These are the specs that the company boasts:
Processor Specs: Atheros, 6th Generation, AR5414
Radio Operation:  Proprietary 900MHz
Interface:  32-bit mini-PCI Type IIIA
Operation Voltage:  3.3VDC
Antenna Ports:  Dual MMCX
Temperature Range:  -45C to +90C (extended temp version up to +95C)
Security:  802.11i, AES-CCM & TKIP Encryption, 802.1x, 64/128/152bit WEP
Data Rates:  6Mbps, 9Mbps, 12Mbps, 24Mbps, 36Mbps, 48Mbps, 54Mbps
TX Channel Width Support:  5MHz / 10MHz / 20MHz / 40MHz
RoHS Compliance:  YES
Avg. TX Power:  28dBm, +/-1dB
Max Current Consumption:  1.10A, +/-100mA
Indoor Range (Antenna Dependent):  over 400m
Outdoor Range (Antenna Dependent):  over 50km
Operating System Support:  Linux MADWIFI, WindowsXP, Windows2000
Advanced Mobility / Quick Handoff:  WindowsXP/2000 Utility with Enhanced Mobility Driver from Ubiquiti
Cisco Support:  CCX 4.0 Supported Driver/Utility also available from Ubiquiti
They also carry ones for the 5GHz and 700MHz frequency range.  If anyone has ever used these or could see a possible usage in a UAV, please comment!
Hunter
  • I'm using the 2.4 GHz picostation and bulletm2 on the ground station. I'm assuming you have a need for higher bandwidth channels, or you'd probably be using a data modem, which is far simpler to use, configure and provide power for. Here's a video demonstrating how video comes up in a not too dense urban region, but with lots of student wifi AP's in the area (>28): https://www.youtube.com/watch?v=abdgfFLFLoE
    When the video cuts out, the onboard wifi has just turned around a corner of a house. Everything else with clear video is direct LOS.
    This is 720p video @ 42fps with 19Mbps fixed bitrate on 802.11n wifi. Static video is around 4Mbps with spikes going to 12Mbps. This is before introducing a 60ms jitter buffer on the GS.
  • The Ubiquity gear is REALLY good and very low cost.
    I swear by it for a lot of different projects. Highly recommended.
  • The 4G connection idea sounds good.
  • I was thinking what about a 4G wireless card on a Gumstix running Linux?  You could add whatever daughter boards you need and transmit data over 4G.  Say, through an AES256 encrypted VPN tunnel.
  • You might want to get a Rocket RM900 instead and remove the board from the case for a UAV.  It is a little big, but transmits at 28dbm with two mimo transmit channels and there is a serial connector (ttl level) on the board.  The firmware SDK/source is available for download on request, so you could add one of the standard serial over IP protocols and use another rocket or a NanoStation (28dbm + 8dbi antenna gain, 60 degree/60 degree directional pattern) for a base station.  As an added bonus, you would get ethernet on both ends for a small IP camera/etc.  All these products will support 100mbps at long range or slower speeds at very long range.
  • Sorry to tell that, it is useless for small drones. You need mainboard to plug this card to. Cheapest and lightest I can find is Mikrotik RB411, form factor 105x105mm about 100g. Then you can change firmware to OpenWRT. Pretty complicated....
  • Wow, Impressive!
  • I've personally run a Maxstream xtend radio at 73 miles with a rubber duck on one end a 1m dish on the other with 100% copy at 115K baud. So if you don't need images, thats pretty good.
  • I'd imagine you can acheive this by using this: http://www.amfeltec.com/products/flexible-minipcie-to-minipci-adapt...
  • However, most of the newer mini PCs have miniPCI-E and not miniPCI slots.
