Announcing our new product listings for mid-summer 2013!
_______________________________________________________________________________________
3D Robotics Y6 and X8 Multicopters - RTF and Kit
We released the Hexa-to-Y6 conversion kit a few weeks back, and now the complete Y6 DIY package and Ready-To-Fly are available. A Y6 design is able to withstand a single motor out scenario, provides a more open and stable view for cameras, and doesn't weigh as much as a traditional Hex (because it uses less parts). It features folding arms to make ground transport a painless affair. This is our new go-to multicopter at 3DR: better performance than a quad at about the same size!
If six motors aren't enough for you, there is now the X8. With the same coaxial motor design as the Y6, but with four arms. This brute is amazingly compact, it's actually smaller than our quads in the front to back dimension, due to the wide angle of the arms. This is the platform to choose for flying your heavy camera and gimbal setups. The redundant nature of this vehicle is a valuable trait when carrying expensive gear or flying over difficult terrain. This vehicle can lose a motor and remain in a stable loiter with almost no disruption . The 3DR X8 is available ready-to-fly only at this time.
APM 2.6 and 3DR uBlox GPS with Compass
APM 2.6 is the same APM 2.5 you know and love, but with one valuable change: this revision of the board has no onboard compass, which is designed for vehicles (especially multicopters and rovers) where the compass should be placed as far from power and motor sources as possible to avoid magnetic interference. (On fixed wing aircraft it's often easier to mount APM far enough away from the motors and ESCs to avoid magnetic interference, so this is not as critical, but APM 2.6 gives more flexibility in that positioning and is a good choice for them, too). This is designed to be used with the new 3DR uBlox GPS with Compass, so that the GPS/Compass unit can be mounted further from noise sources than APM itself.
Note: APM 2.6 requires an external compass for full autonomy. If you are using APM 2.6 with a GPS module that does not have a compass sensor, you must use a stand-alone external compass. We recommend this one with this cable.
New GPS shown as it comes, in a nice enclosure
The board, inside the enclosure
You can also use the new uBlox GPS with on board magnetometer (compass) with your existing APM 2.5, To modify your board, follow the directions here.
_____________________________________________________________________________________________
If you have been wanting to add first-person-view (FPV) capability to your vehicle, our new FPV package gives you everything you need in one kit (including batteries). All connectors have been built in the factory and designed to give you an easy plug-and-play experience -- no soldering required! On-screen-display is provided by our MinimOSD board for real time data telemetry. This is an important safety and convenience feature for anyone flying FPV.
All of these items are available for order immediately.
The FPV kit is ready for shipping today.
The Y6 DIY package and APM 2.6 will ship on July 15th.
Note: RTF Y6 and X8 units will follow the normal 1-2 week turnaround. You'll find those and more on our new RTF store here: http://rtf.3drobotics.com/
Stefan,
The frame weighs ~440g
We do not have any other arm choices, but that is something one could DIY. The arms are 19mm (3/4"), if you kept this same dimension it would be easy to use the kit components. Longer motor leads might be the only need, perhaps you could move the ESCs out on the arms. It would not be as clean looking, but that might get you the extra length.
Thanks guys for the support!
Still no email/ETA from 3DR... sure they are busy, must be a lot of orders to prepare.
I also have a batch of 2.5+ ordered and not shipped (they show backorder now...maybe just replace them with 2.6+ hehe sure no one will complain)
The good news (I think) is that my 2.6 order state is "Ready" whatever it means is better than processing!
Dany
www.CanadaDrones.com
Question:
To the 3DR team... sounds like the patent issue might be serious but in regards to the helicopters what is the maximum payload capacity for the Y6 and X8? Please post a "motor out" video with the helicopters carrying a significant payload. In the sample video I see a little GoPro onboard to record the stopped motor but it would be nice to see that you can still keep flying in a "motor out" condition when we're carrying more expensive stabilized gimbals and cameras. Have you tested motor out with lets say a 650g or 700g payload or at what payload weight does "motor out" fail?
@Autistic, your post from 4 hours ago with the correct link is still there, no one has messed with it.
It did originally seem a little out-of-place as no one else was speaking to that topic anywhere near your post.
Patent wars over multirotors have been going on for years http://www.rcgroups.com/forums/showthread.php?t=441117
Didn't they change 'prior art' to 'first to file'? but I think that was after 2010.
Brian,
Here is the listing for that cable:
http://store.3drobotics.com/products/telemetry-slash-osd-y-cable-ad...
Is it possible to order a Telemetry/OSD Y-cable adapter cable separate from the FPV system?
Kevin, It's time to bust out the AndroPlumber
Chester, we will send you a case delivered for free with your next order. They will be ready for delivery by the beginning of next week, just waiting on the printing. Send me a note if you have any problems. I'm glad to hear that you are happy with your unit!
1
2
3
4
5
of 6 Next
