Yet another Build log - Epp FPV
So my kit from HK arrived yesterday and I should note that this is my first build ( If you see terrible mistakes don't hesitate  to shout;))
3689404199?profile=original
Soldered the carbon rod using some super glue. I installed those holders just in case even though most probably am gonna put the elevator end radder servos on the wing itself
3689404275?profile=original
Glued the 2 wooden parts with white glue , then using superglue to the foam and around it some epoxy just to make sure ( Did I used too much glue ?:P)
Here is a close up
3689404300?profile=original
Thats all for today, also some question :) :
1) is there an easy way to aline the back wing (elevator) with the hole stracture in order to be 90 degrees with the fuselage?
2) shall i use superglue for epp to epp or buy some CA?
  • Guys, what is the best prop for this plane? I'm using NTM35-36a-1400Kv motor and 60A ESC. Thanx!
  • Did you fly this plane ? Do you have a parameter file to share ?
  • thanks for the pics. I was looking for an easy solution to better affix the canopy and putting a rod straight through and just rubberbanding it is awesome.. thanks!
  • The batteries are in parallel. The motor is: AerodriveXp SK Series 35-36 1400Kv / 550w (the quality of this motor leaves nothing to be desired - it is very very good)
    The ESC is the Turnigy Plush 60A
  • Jimmy P.
    What motor/prop/battery combination are you using.  Are those batteries in series?  Nice pics by the way.
    Jason
  • Here are some photos of my mostly-finished EPP FPV.
    Drone
  • oh i see tnx guys :), any tip for the wing alinement ?
  • Cyanoacrylate aka cyano aka CA aka Superglue aka ...
    CA glue is superglue!
    No try and find UHU por if you can.
