35cc Engine vibration
Hi all,
can some one help me to reduice and isolate vibations caused by the the engine (MLD35 engine).
I dont know if the propeller balancing can reduice them!
any ideas?
Thanks,
    Also check your ignition timing as this can be a source of extra vibration and poor running.
  • Any single cylinder engine has this problem, one of the best solutions is to find some isolastic (rubber) mounts.
    http://www.centralhobbies.com/engines/mounts/hydmnts.html
    when balancing a single cylinder engine you don't really "balance" them, rather the vibration is distributed evenly vertically and horizontally.
    First check the prop and see if it is way out of balance,drilled off center or cracked.
    Also, when running your engine do you have the wing(s) installed? I have a Great planes Giant Big Stik with a 40cc and the fuselage will vibrate like crazy without the wings.
    The new version of the FY3ZT autopilot comes with a new Vibration damper and Alu case. This improved the vibration issue from Gas engines alot.
    Some inspiration pictures
    Flight-control-shock-mount-assembly5.jpgFlight-control-shock-mount-assembly7.jpgFY3ZT autopilot
  • I cannot speak for RC engines but as I do build and repair my own car engine I can tell you the problem is universal. To reduce vibrations everything the spins must be balanced to reduce vibration. Reciprocating mass as described in engine tuning manuals is everything that can create a wobble (thanks to it being reciprocating :D) so the more you balance the less vibration you receive.
    Jools Holland famously stated on Top Gear that the only perfect standard engine was a Jaguar V12 as you can place a 6 pence piece (old UK money) and start the engine and let it idle without it falling over.
    Now I can only assume that an RC engine has just one piston making balancing like normal engine problematic. I assume that the largest difference is the prop so get that balanced after that isolation mounts would seem the only option except ripping the motor apart and balancing the little crank (assuming there is room to do so).
  • you might try a variable pitch prop and a governor to keep the rpms at the best balance between efficiency and vibration ,,,
  • not sure how the small engines like this are done but some fo the larger aircraft that i fly have flywheel weights on them to help counteract the vibrations and smooth things out a bit. might be something worth looking into
  • Ok you wont be able to reduce the vibration too much with this engines, but yes you can on the part you wanna isolate, you could try this Shock Absorving Sorbothane or any ther ani-vibration foam.
  • The prop MUST be balanced, otherwise your engine will suffer the effects and also your frame. With this engines, the vibration can not be totally isolated. There are several companies that sell vibration isolating mounts and standoffs , but my suggestion is to isolate the electric components to protect them from the vibration.
    BTW, where are you trying to mount it? what kind of frame? balsa & play? composite? let us know so we can suggest you better ideas ;) I have experience with giant scale planes and also with this engines
    Welcome to the world of gas, diesel, and nitro.
    I've flown nitro engines for 40 years and have switched to the EP world wholeheartedly... but then again, I no longer fly anything that would take a 35cc monster like that.
