Version 2.4 of the ArduCopter code is now available in the AP Mission Planner and in the downloads area. Although not as big a change as the 2.3 release, it still includes a respectable number of enhancements and bug fixes.
Enhancements:
- massive reduction in memory use (>2k saved!) due to Parameters change and APM2 baro lib fix. TradHeli code can again advance in hand with the quad code
- improved throttle range in stabilize mode. You may find that it takes slightly higher throttle than previously during hover but hopefully you'll find that you have more useable range of the throttle stick as well.
- added TUNE_LOW and TUNE_HIGH for CH6 Tuning (I.e. to set tuning range between 2 and 6 set TUNE_LOW to 2000, TUNE_HIGH to 6000)
- new ACRO_P gain for those who like to fly in ACRO (aka Rate) mode
- Loiter improvements including scaling of X speed
- Easier to use motor testing. see the videos for quad and octa-x-coaxial.
Bug fixes:
- remove unnecessary block for next GPS value before saving home location
- remove wobble on take-off
- turn off camera pitch control (which uses channel 6) when using channel 6 for tuning
- reduced rate of decent when landing using sonar
- Add support for CH_10 and CH_11 for APM2 users
- fixed Log_Read_Control_Tuning so that it doesn't read too many bytes
The default PIDs are optimized for a 3DR/Jdrones quad with 850 motors and 10" props. If you're using more powerful motors/props, start by turning down Rate Roll P in 25% steps.
Thanks go to the numerous contributors including users and their detailed bug reports, developers and testers. Hopefully all together this will add up to a nice smooth release!
As per usual, please post your comments, issues in this discussion. For enhancement requests for future versions, feel free to add them to the issues list. Note: you can "star" an issue to receive emails when someone comments on the item. On the dev side it helps us because we can get an idea as to which feature requests are the most popular by sorting by the number of people how have starred each issue.
Great job! By the way: can I know which version of MAVLINK does it use? Mavlink 0.9 or mavlink 1.0? Thank you
Just got the APM 2 in today. It linked up well to the copter frame based on the APM 1.
Tomorrow I will fly it with a camera gimbal.
It will be interesting how the certain vibration harmonics happen.
I successfully uploaded 2.4 via the MP to an APM 1.4 1280, thanks guys.
At the risk of nagging: is there any support yet for the X8 frame configuration in this release? Couldn't set it up using the MP Mavlink, can it be done via CLI? Thanks and keep up the good work.
BTW I can use Arduino but not clear as to what to tweak before uploading.
when switching between Alt_Hold and Loiter I get some altitude deeps. See attachment.
Is Loiter holding altitude or only manual throttle?
Pablo
PS: My Mission Planner has changed to spanish!!!!!
WARNING: RISK TO CRASH YOUR QUAD AT THE MOMENT, DUE A DCM BUG!
There's big problem with dcm "fast" (I have already occurred), a complete blowup, stop to work and don't restore, high risk to crash if brings the quad to do pretty aggressive maneuvers.
The dear Roberto Navoni found the problem, and I replied for two times in a row in 30 seconds, with my little quad in my hands (disarmed motors), therefore is not a random thing, it's real problem.
Replicate the problem: quad in your hards, motors disarmed, nose up over 90°, i suggest 180, like inverted flight and again down (return orizontal), repeat the step some time and the DCM go in a complete blowup, now you can see the hud completely gray... blowup!
Apparently the problem occurs only without gps fix, regardless they should not do.
I tried both with 2.4, 2.4.1 and with latest GIT, the problem is the same.
The problem has been present for months, is that no one had ever noticed.
Alert was due, even if it is a situation quite difficult to replicate in flight, but regardless of this they should not do.
One thing is certain: HUD should not go gray! :-)
Stay tuned for future fix, and now fly at your own risk (my quad remain stationary for a while to the ground).
Here my video with the bug.
-= Marco =-
(AC Dev Team)
ArduCopter 2.4.1 on MP and GIT:
For all users who are already using version 2.4 I strongly recommend upgrading to 2.4.1.
That fixes a small problem, however, is not indifferent.
Is not necessary to reset the eeprom or APM after the upgrade.
The motors test that I created for the hexa is not included in the version inside the planner upgrade, but only in the GIT (at the moment)... thanks to Max Levine for the first structure of this code.
Marco
Can any of you PID gurus :) tell me what param may causing a sort of "rocking chair" effect ? If I lean the quad to any side and then return to neutral, I get sort of a decaying sin wave oscillations of about 3 or 4 times (ex : 45º -> stick to neutral -> -10º -> 5º -> finally leveled) I tryied different values on rate P but didn't seem to make any difference (from 0.09 to 0.150).
Also there are some params that we don't generally touch on the left side (params list) named LOITER_LAT_P, LOITER_LAT_I, LOITER_LAT_D, ... what are these ? When we tune Loiter in the boxes, that changes the HLD params (I think meaning HOLD), so what are the LOITER params for ?
Thank you.
I have a serious problem since upgrading my 3DR Quad to 2.4 and switched to new remote (Graupner MX-20). When I wanted to give it a try earlier today it just flipped. Back home I checked all settings, made sure its in X-Mode, remote inputs, etc. All settings seem good.
When doing the hand test it works against something, but not really the right direction. When I push Pitch or Roll on my remote in any direction it feels like only Front-Left and Back-Right spin faster, but only those two, no matter what.
I already downgraded to 2.3, switched back to my DX6i Transmitter. Still not working. Upgraded to 2.4 again, did a Reset from CLI, did the motor test. Test is ok (right order/direction). But still acting wrong. Since I didn't change anything in the wiring I'm totally clueless.
Any idea welcome!
My quad still gets the "leans" bad, log file attached. My APM2 has been placed consecutively on 3 different types and densities of foam from firm to very soft. Problem still persists.
Hopefully (please) can someone analyze the log and figure this out?
leansflight.log
ArduCopter v2.4xp2: Here some videos samples of full AUTO-LANDING tests flights in HIL mode on AeroSIM-RC 3.83 with a Raptor 30 type helicopter (H1) done with the firmware ArduCopter v2.4xp2 (JLN mod). The official v2.4 firmware has been improved with a special Auto-Landing mod which uses only the BARO sensor.Tested with an ArduPilot Mega v1.4 connected in HIL mode on AeroSIM-RC v3.83 through the APM Mission planner.
Regards, Jean-Louis
