ArduCopter 2.9 / 2.9.1 released
ACRO bug (fixed in 2.9.1b): while doing flips in ACRO mode, if you switch to Stabilize while inverted your throttle will go to minimum.  To regain throttle control you need to switch back to ACRO then back to Stabilize again (i.e. switch to stabilize twice).  You never lose control of roll/pitch/yaw.
Loiter/AltHold/Auto/RTL bug: if you switch into these modes with throttle at zero motors will go to minimum until you raise the throttle.
Auto mode altitude bug (fixed in 2.9.1b): setting a waypoint altitude greater than 320m over home altitude may wrap around and instead be interpreted as a low altitude.
ArduCopter 2.9 is now in the mission planner and the downloads area!
The major improvement is we use inertial navigation to improve altitude hold.  This increased reliance on the accelerometers means you must do some additional set-up before flying:
1. Perform the new accelerometer calibration in the mission planner (video).  The auto-trim metho has also changed (video).
3690987999?profile=original
2. Add vibration dampening foam between your frame and the APM.  Some suggested materials: DuBro, gel, hk foam.
3690988058?profile=original
 3. If upgrading from 2.8.1, modify the throttle and altitude PID values:
  • Increase your Throttle Rate P, reduce I to zero, increase D
  • Increase Altitude Hold P, reduce I to zero
  • Tune Throttle Accel P and I terms but try to keep P about 1/2 the size of I
3690988113?profile=original
Here is the list of major changes (a more detailed list can be found in the release notes):
  • Alt hold using inertial navigation (Leonard, Randy, Jonathan)
    • AUTO_VELZ_MIN, AUTO_VELZ_MAX parameters control the max climb/descent rate for the autopilot (cm/s)
    • PILOT_VELZ_MAX controls max climb/descent rate for the pilot (in cm/s)
  • Landing improvements (Leonard/Randy).  Copter will descend to 10m or until an object is sensed with the sonar.  Then slows to 50cm/s descent (speed can be adjusted with LAND_SPEED parameter). (video).
  • Surface tracking with sonar (Randy/Leonard).  Copter will attempt to maintain current distance from objects in front of sonar regardless of altitude.  Only used in alt-hold and loiter, not used for missions.  Sonar can be enabled/disabled with CH7 switch. (video)
  • Failsafe improvements (Randy/Craig/John Arne Birkeland) including bug fixes, additional check for PPM encoder failure and implementation of battery failsafe.  Set-up instructions are here.
  • Mediatek gps driver accuracy improvements and use of SBAS [Craig].  Instructions on upgrading your mediatek to firmware 1.9 are here.
  • Traditional Heli improvements (Rob) including (a) bringing heli code back into the fold, (b) enabled rate controller (previously only used angle controllers). (c) fix to rotor speed controllers - now operates by switching off channel 8.  (d) allow wider collective pitch range in acro and alt hold modes vs stabilize mode  (e) bug fix to allow collective pitch to use the entire range of servos
  • Acro trainer (Leonard). Copter will return to be generally upright if you release the sticks in acro mode.
    • ACRO_TRAINER : set to 1 to enable the auto-bring-upright feature
    • ACRO_BAL_ROLL, ACRO_BAL_PITCH : controls rate at which roll returns to level
  • Camera control improvements (Randy/Sandro Benigno):  (a) AP_Relay enabled for APM2  (b) Trigger camera with CH7 or DO_DIGICAM_CONTROL command  (c) Allow pilot override of yaw during missions and fixed CONDITIONAL_YAW command.
  • PPM sum support for transmitters with as few as 5 channels (Randy/Tridge/John Arne Birkeland).
  • Performance and memory useage improvements (Tridge).
As per usual PIDs are optimised for the 3DR/jDrones quad with 850 motors and 10" props. If you're using more powerful motors/props and are seeing bad flight behaviour in stabilize, start by turning down Rate Roll P in 25% steps.
Special thanks to our testing team lead Marco and the dedicated bunch on the 2.8.1 release thread who put their copters at risk while testing the pre-release version.  Some of their videos are here: 1 2 3 4 5 6 7 8
Please feel free to report issues you find in the discussion below and/or add them to the issues list.
  • I missed information on wiki and around(which one is main instructions page anyway??) that Y6 needs to be V shape on MissionPlaner arducopter level page...till now it was X..stupid me i try to fly..no left-right commands all messed up... luckily i manage to land the bird down without problems....Firmware V3.0 rc4
  • Hi Guys, just following this discussion as I am also having the same issue with an overpowered quad. Thanks for all the hints. I also propped down from 15" to 12 and fixed the problem with stability and weight. It got the rpm's up to the area stability was best. Also, my built in magnetometer was getting affected by induced magnetism from my dc power lines under the apm2.5. Did the mod With a external magnetometer and now is solid without any angular drift on power up. ( I think that was my issue from the start) Going to put the bigger props on as the payload is increased. Testing continues....
  • TAKEOFF STABILITY WITH 2.9.1b
    I have an issue with run up and takeoff stability.
    My F330 is difficult to get off the ground nicely i.e. with no pitch/roll manual interaction.
    Once it is in the air, it works well. Alt_Hold also works smoothly.
    It hovers nicely at 419 (from the log) which aligns with around 40% throttle on my DX8.
    The Mod/Stabilize line in the log suggests a hover speed of 320 approx. Why not 419?
    I have left THR_MID at the default of 500.
    Initially, with THR_MIN at the default of 130, the unit acted by a provoked pit bull terrier – sprang into the air and had to be brought down with a total throttle cut.
    I now have THR_MIN at 35. Tests at higher settings did not help.
    How should I approach analysis to achieve an orderly takeoff?
  • Hi all,
    slightly off-topic but perhaps others will be interested too:
    Will be supported in some later version of ArduCopter V-Tail configuration, e.g. for quad?
    I did some searching through discussions here on DIYdrones but didn't find satisfactory answer to this question.
    Someone advise just change motor mapping, but i thing it is not that easy and I really didn't find actual solution (changes in source code) how to make it possible.
  • Copter disarmed in flight.
    My son had a copter crash yesterday (caused by a TX antenna pigtail problem). The copter alternated rapidly between RTL and STAB, which he didn’t know at the time but he just thought it was not flying properly. Before he got it back it disarmed at 80mts and fell like a rock.
    I guess the logs will help – will post later. In the mean time, what are the disarming conditions?
  • I had a crash like yours too, finally It was a motor axis loose.
  • Open pilot will have AUTOTUNE VERY SOON(ITS BETA) why can we have the same???
    http://wiki.openpilot.org/display/Doc/Autotune+Setup#AutotuneSetup-...
    https://vimeo.com/48808497#
    https://www.youtube.com/watch?v=ofdiwF_fgMQ
    A little preview  for your evaluation...
    Bests, Marco
  • I flew both my 450DJI crash-quad (APM1 board) with 2.9.1b and my big quad (APM2.5) today and both have an issue with loiter and alt hold. The crash quad bounced up and down about a meter and the big quad locks in ok and then just out of the blue it just drops down a couple of meters. The crash-quad fly's really well in stabilize.  Could someone please look at my log and see if you can spot what is wrong? Armed starts in at 32% Loiter at 40% Althold at 43%
    2013-04-07 10-07-38.tlog
  • Finally got to try the follow me mode on 2.9.1. Its so fun but kind of spooky too.
    Bit clunky to set up but once it is going it feels like a puppy dog :)
    https://www.youtube.com/watch?v=L7dmiUgbvaQ&feature=youtu.be
