ArduCopter-3.0.1 released!
Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
3691038784?profile=original
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to Marco, DaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found here, here, here, here, here and here.  Thanks also to MichaelO for the MP changes required for this release.
  • Further more, tried MP 1.2.53
    Started with the working external compass, then did a hot swap testing the 2 not working, (se above) and the now show OK in the HUD, strange?
  • Hi, I have some questions regarding externall compass.
    I have APM2,5 from RCtimer
    3 HMC5883L board, 2 of them report "compass init error"
    When going in the test/compass all 3 then show ok (se pic) but only 1 work in the HUD.
    Tested all 3 with an arduino sketch and a different board "Pro mini" the all work.
    Another issue, why must the mission planner first have to load the latest software every time i click on hardware tab?
    When doing the live compass calibration, after the 60 seconds it show 0 sec and then stops, have to close MP and restart. i.e it never says compass is done.
    Thanks/Goran
    3692783043?profile=original
    3692782991?profile=original
  • I have been flying for months with no issues on 2.9.1b until I upgraded to 3.0.1. I ran through all the calibrations including compassmot using a 3DR power monitor sensor. I even used anti vibration foam on my APM 2.5+, did a live calibration of the compass and calibrated the gyros. I even recalibrated the ESCs. I have spent 2 days on this. Slowly power up the motors in stabilize mode and on a flat concrete surface, as soon as the is just enough power to lift off........boom, the copter flips over on its back.
    I reloaded the old firmware and bingo. I'm flying great again. I don't know what gives because there seems to be plenty of people flying with rev 3.0.1 and loving the improved stability. But something must be amiss because there are too many reports of the backflip occurring among us experienced APM quadcopter pilots.
    Take a look at the APM blog over here. Several other pilots are experiencing problems with ver 3.0.1 doing backflips on takeoff after upgrading from 2.9.1b
    http://ardupilot.com/forum/viewtopic.php?f=3&t=1870&sid=9ee...
  • well I managed to get the vibrations down to a really good level. But now it seems the baro and sonar are slowly drifting apart as the flight progresses. Any Idea why that would happen? Previously they were very tight.  All I did was balance the props and added a few grommets. These logs were the last few test flights I did in my lounge room
    Also what are the left and right graph this buttons for?
    2013-07-24 18-53 1.log
    2013-07-24 18-30-09.tlog
    2013-07-24 18-54 2.log
    https://storage.ning.com/topology/rest/1.0/file/get/3692782300?profile=original
  • MR60
    Need second (or more) opinion for vibrations:
    I see in my last Tlog what seems to me huge xacc and yacc values (while zacc seems ok within plus or minus 0.2g) : is it a mission planner display scaling thing or a huge problem with my vibrations ? enclosed my tlog and graph below:
    3692782270?profile=original
    I notice also a difference of "zeroing" between X and Y axis : why is that ?
    2013-07-24 15-33-42.tlog
    https://storage.ning.com/topology/rest/1.0/file/get/3692782148?profile=original
  • Randy.
    You may have seen the debate regarding reliability and redundancy.
    Could I ask, in all the logs and problems you have looked at how many times have you seen an APM just fail, not caused by power problems.
    Perhaps we could do a histogram survey page about the causes of peoples crashes. Categories like.
    Prop
    ESC
    Motor
    GPS
    Compass
    Battery
    APM power
    APM
    Wiring
    Other mechanical
    Pilot (Tuning/PID/settings)
    Pilot (flying errors).
    Vince
  • Hi Randy ...Are you able to check my logs just once more?3692781801?profile=original3692781692?profile=original ..I have redone the APM Mount ..picture attached ..  all seems good flys well ..just a bit of mild dipping on the arms when hovering..
    2013-07-24 13-49 1.log
  • Hi when upgrading MP does it load default PIDs and change my settings ...or does it remember all my params ..I know that Params are stored on the APM as Randy had said ..I was just wondering how updrading MP affects settings do i need to redo set ups such as compassmot Acc calibration etc.. ?
    P.S I have discovered that when mounting the APM onto a weighted rubber/ cushioned isolated plate it is a great idea to fix all wires the attach to the APM onto the same plate leaving a little slack going to the APM ...this way any vibes travelling up from the wires is arrested by having them fixed to the Ali plate...before they attach to the APM .cheers
  • Has anybody got a APM 2.5 version 2.9.1b hex file for a quadcopter for me so that I can get to fly again?
  • Hi, I just updated my APM2.5 from 2.9.1b to 3.0.1 and I noticed that now the artificial horizon in the Mission Planner (1.2.61) does something strange: As you see in the sceenshot it shows a pitch of -5deg although the copter is located perfectly horizontal (shown by the numbers below). What's the matter? I made the Accel Calibration several times, so that can't be the problem...
    Markus
    3692781092?profile=original
