ArduCopter-3.0.1 released!
Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
3691038784?profile=original
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to Marco, DaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found here, here, here, here, here and here.  Thanks also to MichaelO for the MP changes required for this release.
    Super smooth APM Copter V3.2-DEV, all recorded in Loiter... ;-)
    Have fun!
    Marco
  • 3.1-RC7, It's very perfect on Loiter mode.
    Controller : APM 2.5 and GPS uBlox LEA-6H with Compass
    Frame : Tarot Quad 650
    Motor : T-Motor MN3110-26 470KV
    ESC : T-Motor 40A
    Prop : T-Motor Carbonfiber 15x5
    Battery : Zippy 4s 8000 mAh 30C
    Radio : Turnigy9XR with Frsky Module
    Receiver : FrSky D4R-II Receiver
    Hover Time : about 24 mins.
  • Hi,
    I have scratch installed RC7 on my X8 with PX4 + IO and have some questions.
    here the HW 8 x Rctimer 40A Simonk + HP4215-460 Rctimer 15 x 5,5 CFK ,R6303SB receiver
    4kg with Gimbal and Battery (camera was not installed)
    1.I had to do compass calibration several times (got bad compass heath and offsets to high) any idea ?
    2. Any update if Futaba R7008SB is supported via SBUS ? didn't work in the past !
    3. attached a log file (had some twitches around line 4200-4300) i would appreciate if someone could have a look.
    Thomas
    1.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3692889711?profile=original
  • Arducopter 3.1 rc7. Found I had to drop the Stab P down a bit after autotune this time was 7.6 and dropped back to 5.
    Then went train spotting...
  • What’s the latest estimate on the next general firmware update? Is their any hope of me getting it to use for the holidays?
  • Not sure if this is a problem but it sure scared the BeJesus out of me.
    I wanted to compare the motor test sequence on my quad that has RC7 to a larger quad (X650)  running 3.0.1  to see if the sequenced matched both configs. I left my blades on the smaller X350, went into mission planner, went into the CLI, while waiting, i hooked up my battery for the motor test. Normally i hold the X350 down with my foot on one of its legs.
    its a good thing i did, because as i turned to look at the CLI, the Motors revved up to mid throttle and wouldnt turn off. my radio was on, the USB was in the Quad and the battery was connected. i had to turn the X350 into the ground to where i could disconnect the battery. maybe we should note on the CLI page
    http://copter.ardupilot.com/wiki/connecting-your-rc-input-and-motor... that it would be a GOOD idea to do this test with No Blades on.
    the videos on the page show blades on, i naturally never thought the Quad would behave that way. i believe this was before going into setup as the CLI is connecting to the Quad, there was just binary code typing across the screen.
    also as we're on the subject, the way the CLI spins the Motors is the way the APM 2.6 board expects the motors to be configured? at first, on the X650, my props tested top right, bottom right, top left, bottom left. this isnt the way the XAircraft manual portrays the connections as it shows the motors in a counter clockwise config?
    thoughts?
  • Hello guys. I need some help.
    I am using the latest fw rc7....
    I have installed the ext mag too.
    after flying 15minutes on compass learning. I`ve checked the offset numbers...
    they are low as 40,42 and 6 on z axis.
    Mag interference is oscilante from 180 until 330.
    All cables are pretty twisted. Opto esc, external bec, servo wires and power lines all twisted.
    Ext mag and gps 10cm away from power lines. FC is 4cm away from power lines too.
    I don't know what to do anymore, I always have the message "bad compass health"....
    in the previous 3.01 I don't have that message.
    any clue?
    thanks
    FYI, I've been chasing a problem for the past few days with missed GPS messages.  These are what we saw in John's logs and was one of the reasons I pulled -rc6.  -rc7 deals with these missed messages so you generally won't notice them but I wanted to tell people how to spot them in any case...maybe with the hopes that extra data points will lead to the cause (and thus solution).
    You can see them by loading up a flight's dataflash message into either the mission planner or excel.  If you're using the mission planner then you should filter to only show the GPS messages (see orange X in the pic below).  If your ublox GPS is working perfectly then all messages will have the "TimeMS" spaced 200ms apart (except for times where it's interrupted by you arming or disarming the copter).  If there is a missed messages then the spacing will be 400ms.
    3692886597?profile=originalActually an even faster way to find out if you had missed messages is to filter for the "PM" message and check the INAVErr column.  If it's all zero then you had none.  Generally if there's a missed GPS message you'll get about 20 INAV errors per missed message.  20 sounds like a lot but that just means it went 0.2 seconds (i.e. 200ms) without an up-to-date GPS message.
    3692886769?profile=originalAnyway, if a couple of people could check their logs to see if they're seeing this I'd greatly appreciate it.
  • i Wonder what kind of controller they use http://inhabitat.com/worlds-first-two-seat-electric-helicopter-succ...
  • Running ArduCopter 3.1-rc7 on small H-quad. These ESCs on this quad are Plush 18a took from my old stock. The motors are very sluggish. And found ESC Update Speed (ArduCopter:RC_SPEED) has been set to 490Hz, I just do not know when. After lowering this value set to 400Hz and looks fine at this moment. Any sense?
