ArduCopter-3.0.1 released!
Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
3691038784?profile=original
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
  • Please excuse me if this is a dumb question but why is there a "Graph this data Left" and "Graph this data Right" button in the Log Browser?  I've tried both and they produce the same graph.  Am I missing something perhaps?  Thanks,
  • Thanks Randy. I'll be careful because I know of the issue. I hope that other Y6 owners are made aware of this issue if they try the new frame type.
    By the way, I just got back in from testing with frame 10. After making the APM motor changes, I only had two reverse the rear boom two motor directions.
    I can say that it flys quieter, smoother, and loiters rock solid with absolutely no tail wag.
    Also it looks like its running a couple amps less in my logs compared to similar loiters on R7 with original frame.
    So far, I am very happy with this new frame and release.
    Thanks to all who contributed to this improvement.
    Mike Governale
  • MP - Feature Addition?
    Would this thread be acceptable to request additional settings/selections on the 'Quick' tab menu for MP?
    - Add the PIDs so that when we are Tuning or Auto Tuning we can monitor what the values are. It would be handy for manual tuning. Possibly for Auto also - When/IF the values start getting too far from what would be acceptable we can cancel the action.
    I do see that the selections are getting quite large - possible group them to become pop ups for the specific groups? Such as a POP UP for the PIDs?
  • It seems noone is interested by RTH sudden stop (will bring down heavy copters swinging like a leaf) and then 50m fly away into anything it hits, without control, bug video documented here http://www.diydrones.com/xn/detail/705844:Comment:1497459
    You can try for yourself but leave some room ahead:
    accelerate in ALTH or Stable to 4m/s or more then hit RTL and hold your pans.
    3692897450?profile=originalBTW, another bug is that when copters auto-lands in failsafe with disarm, log is no more visible,
    3692897959?profile=originalI can't find the failsafe landing log after this flight! see the clip with failsafe landing and autodisarm here http://www.diydrones.com/xn/detail/705844:Comment:1497352
  • I can't find octa v support in this firmware. Does anybody tell me if support this frame in 3.1 firmware?
  • Does alt-hold mode require compass and magnetometer to be turned ON?
    I turned them of for the reason that the APM mission planner didnt detect my compass sensor. it failed calibrating it and so i disabled it.
  • Bad GPS Health
    I did not find a definitive answer on search.
    FW 3.0.1 rc8
    APM 2.5
    Sat: 8
    GPS: 3D Fix
    RSSI: 100%
    Mag: ~339
    Bat 12.3V
    USB Cables both good. Upgrade with no problems and MavLink - MP connection quick. Well, as quick as MP is slow.
    Performed with and without Bat connected.
    What is the definition of Bad GPS Health and what is the ramifications of ignoring it?
  • Randy,
    I just updated to the R8 beta and made the change on my 3dr y6 to the rear props. I replaced the 10" prop on top of rear motor with a CW and the replaced the 11" on the bottom with a CCW. I changed the FRAME from 1 to 10. Do I also have to reverse the ESC on the two rear arm motors to get them to spin opposite for this prop change? When I ARM and the motors spin up, they are still spinning in the old direction, even with FRAME=10. Also, I noticed that when I change the FRAME to 10 from 1, and I go back to the Frame type in MP, it also changes it to the "plus" radio button selected.
    We have been running two 3DR y6's with great success on 3.1 y7, 6, and 5 beta. There was an occasional slight yaw wag that we hoped might be solved with the new prop changes supported in r8.
    Please let me know what I might be doing wrong.
    I'll await your reply before moving any further.
    Thanks,
    Mike Governale
  • Is there a Main Thread for Mission Planner questions? i have purchased a 6 position Switch for flight modes, but Mission planner is not reporting the selections i made correctly, mis reporting them as stabilize even though the drop down box clearly says Loiter. this affects position 2,3,5 where no matter what i select, it says Stabilize. the Radio is a TH9X Stock firmware, six position switch purchased from Ebay. sorry i just cant find the mission planner thread.
  • Hello everyone,
    I think there is a bug in 3.1-rc7. I am using the 3DR mini osd (updated to v2.0 including character set) and the flight mode is not displaying. Difficult when flying FPV. Everything else displaying fine.
    The setup is AMP 2.5, standard 3Dr radio for telemetry, Hex.
    Attached are some pics.
    What do you think?
    Thank,
    SAA
