ArduCopter-3.0 ready for wider use
ArduCopter 3.0 is ready for widespread use.  To make the transition easier, this time we are asking people to voluntarily upgrade from 2.9.1b for the next month or so before we make 3.0 the default firmware downloaded by the mission planner.  The new version can be found in the Mission Planner's Beta firmware's link, firmware.diydrones.com, GitHub and the new Downloads Area.
Warning #1: A bug was found in the FENCE in which if you lost GPS it could lean at extreme angles as it tried to maintain an invalid position.  This is fixed in AC3.0.1-rc1.
Warning #2: This release has not been fully tested on Traditional Helicopters
Warning #3: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the WPNAV_ACCEL to 100 and Loiter PID to 0.2 (from 1.0) to reduce aggressiveness.
  • Safety improvements:
How to upgrade:
1. Make sure you are using Mission Planner 1.2.59 or newer.
http://ardupilot.com/downloads/?did=63
2. Click on the MissionPlanner's Firmware screen and click the "Beta Firmwares" link on the bottom right.  The version numbers should update to "ArduCopter-3.0.1rc2", then click the appropriate frame icon and it should upgrade as per usual.
3691031698?profile=original3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3dr frame can be seen in the image below.
3691032069?profile=original
3691032034?profile=original
4. If you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware.
http://copter.ardupilot.com/wiki/common-ppm-encoder/
http://copter.ardupilot.com/wiki/common-ppm-encoder-apm2x-atmega32u2/
Special Thanks to MarcoDaveC and the rest of the beta testers for putting their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
Added by Craig:
Please watch Randy's videos on setting up and flying APM-Copter 3.0 before you go flying.  They are excellent!
3DR Quad Set-Up Suggestions        http://www.youtube.com/watch?v=33Tl_rjhQEE
AC 3.0 "Live" Compass Calibration  http://www.youtube.com/watch?v=DmsueBS0J3E
AC 3.0 CompassMot Setup                http://www.youtube.com/watch?v=0vZoPZjqMI4
AC 3.0 Pre-Arm Checks                      http://www.youtube.com/watch?v=gZ3H2eLmStI
AC 3.0 Fence                                         https://www.youtube.com/watch?v=HDnGdo54o-4
AC 3.0 Maiden Flight Checks             http://www.youtube.com/watch?v=NOQPrTdrQJM
  • Will it be possible to use the same trick to remap motor outputs to different physical output channels as you suggested for v2.9.1b?
  • T3
    Quick question: where did crosstrack and tilt go?  I'd like to tune them but they are not showing up, even in advanced params list.  Did their names get changed?
  • Strange loiter and alt_hold issue, I have done the manual compass calibration, the compassmot, leveled, etc etc. My quad flies really nice but, when I switch to alt_hold or loiter my quad just slowly ascends, until of course I switch back to stabilize.  Has anyone else seen/experienced this?
  • Im running AMP1 on my quadcopter.  I've done all the calibration processes.  I dont have a power module but got 46% when I did the compassmot over telemetry vs throttle.  Now when I try to arm it I get the "magfield" error.  I checked the status window and my magfield varies from 190~193.  Any idea why it would be so low?  I believe it should be near 530 for AMP1.  Attached is a short TLOG file... Thanks
    2013-06-20 22-55-51.tlog
  • I am in the process of switching to v3.0.0. I did start with updating my mission planner (1.2.35 currently) first from the 'help>Check for updates' option.
    I thought it was going to ask me what update it found and I would approve it. It just went to updating straight and after that I got the following error message:
    "To run this application, you first must install one of the following versions of .NET framework:
    v4.0"
    I never read this anywhere before. Do I need to download an install v4.0 of NET framework?
  • Hi Randy and Dev Team,
    Please advise on questions below:
    * My quad was overshoot for around 80cm at some of waypoints and fly back for correction, how to tune it for smooth stop at waypoints?
    * After reaching waypoint, the quad will stop and change yaw heading first then start fly again. Can we set to change the yaw while still flying to the next waypoint without stopping? in order to achive smooth way point transition especially for video shooting purpose.
    * Somehow I manage to broken (or receive the broken board) the input 3 for THR and APM 2.5 cannot receive my THR input (and no prob with my radio receiver). Can I re-map one of input i.e Input 8 for THR ?
    As always, many thanks for your advise and support.
    Waladi
  • Ill try this again - i am seeing my compass is off by +90 degrees (yaw reads 360/0 when pointed due west). It looks like the compass rotation parameter doesnt affect it either.
    What can i do to correct this?
    Brand new APM2.5+, btw
  • I loaded V3.0 to my APM2 which is on a Tricopter
    The controller won't pass yaw commands from the TX. It does send commands to maintain the current heading [but not a user input from channel 4] so the servo is working OK.
     -The radio has been calibrated.
     -If you watch the servo outputs in the failsafe section you can see there isn't any output to CH 7.
     -Simple and Super Simple are disabled
     -I compared the V2.91b params to V3.0 and can't pick out the problem.
     -The Tricopter flys OK but with no yaw so it is the correct firmware.
    I've attached my params
    Can anybody help me?
    Bob
    APM 3.0 tricopter params.param
  • Guys,
    Thanks, I loaded 3.0 and my hex is flying like a naza now... All my compass issues is gone, after I did the calibration explained by Randy. Also did the compasmot. There is a slight "see-saw" or wobble in loiter, but I guess I can get that better with settings. Not sure exactly which, but great work... 3.0 is going to be great!!
  • My quad is flying well with the V3.0 update (thanks to all!).
    I did the compassmot calibration and it returned a 63% interference level. This sounds very high, but loiter is functioning well, as are all other aspects of its flying.
    Should I strive to reduce this number?
    Best,
