Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Guys, has Mission Planner caught up with the flight modes available in 3.2 yet ?
The reason I ask is that Hybrid mode is not being reported correctly in the flight status screen.
Martin
NullVox,
That'll be my fault for messing it up as part of the merge. I'll merge your pull request after we get through the AVC competition this weekend.
Phil, to test out a DO_SET_SERVO sequence like that does the copter need to be armed and motors spinning ?
Martin
Phil,
So the difference is because of the rewritten AP_Mission library with AC3.2. The do-digicam-control does work with AC3.1.5 though. I used it successfully to drop the tennis ball at last year sparkfun AVC competition. The issue I think is that in the mission it's not giving any time for the do-set-servo command to run between the waypoint commands. I would still expect the 2 second delay on the 2nd waypoint command would give it enough time to complete though so I'm unsure why you're finding that that one isn't working.
Glad to hear that it's working well on AC3.2 though. AC3.2 better handles "do" commands that appear at the beginning or end of missions in particular.
Randy, as with the GPS glitch detection would it be worth having an altitude jump detection? So if the altitude jumps by more than the average or above average copter is capable of then this protection would stop massive attempts to change altitude (or is this built into the GPS glitch detection?)
Graham,
Yes it's a very worthwhile feature to have and it's on the to-do list here. It's actually already built-in to the EKF which can be enabled on AC3.2 using AHRS_EKF_USE parameter. I'm undecided whether it's worth re-implementing this check for the existing inertial-nav or whether we should just continue to put up with the risk until EKF becomes the standard position estimation method (that will happen with AC3.3).
Hi Randy,
Regarding Altitude glitch detection:
If you manage to fit EKF in the APM2 I would say to wait to EKF being the standard position estimation method.
If not, please consider to include it in current inertial-nav ;)
Miguel
I am not sure, but I think the processor requirements of the EKF were beyond the capabilities of the APM board.. could be mistaken though?
Just Thought the group would like this, Like Google street view But with Drones http://www.travelbydrone.com/ what will they think of next?
HI
please to see log
http://forum.rcdesign.ru/attachment.php?attachmentid=948772&d=1...
ac 3.2 stop motors in altitude hold mode when rc3 in 950 (rc3min = 1008)
user error - throttle failsafe -disabled
arducopter dont hold climb rate - full stop of motors
223
224
225
226
227
of 262 Next
