ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • I see RC3 in the 'latest trunk' version in Mission Planner, but it doesn't show up in 'Beta firmwares' in Mission Planner, so does this mean not to use RC3 as a 'beta' level yet?
      Rich,
           -rc3 will be out shortly, probably later today or tomorrow.  It's close which is why I've updated the version name in master (aka 'latest') but there's a technical issue (the pixhawk is freezing up after code is loaded) that's come up when we use the latest version of the arm gcc compiler for Pixhawk.  We just want to make sure we understand the cause before pushing out the new version.
      • Thanks for the update. Sorry for seeming to be impatient.
        Having a Pixhawk, I'm happy to see that you're looking out for the PixHawk version. :)
  • Any news on RC3 yet? :) or where can we go to follow the progress?
    • Dear Randy,
      I saw in repo that RC3 is ready and out.
      When it will be available in Mission Planner? (I have the latest beta…)
      Thanks in advance.
      Best regards
      Adrian
    1. Is this the place to follow the latest releases and give your user input?
    2. If so Is there an update links for the opening section?
    3. Where is the manual being updated?
    4. Any other links for us that are trying to stay upto date?
    5. How about for Mission-Planner and Arducopter etc.?
    (I have 2 APM's and 2 PixHawks on quads)
    Thank  You?
  • 3.2-rc2 is doing very good so far, on my apm2.6, hybrid mode is especially good, for beginners as well for advanced pilots. As for now, no side effects :)
