Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
here it is.
pls let me know if you think this is a board's fault.. but so far, flew great 3 full batts, on the 4th batt, I parked it in a tree again, this time the tail servo got damaged, so now there is a little play in the gears and that produces a lot of vibration, will have to order a new set of gears.
2014-09-01 11-35-00 1.bin.log
Artem,
Yes, I'll check your logs tomorrow for sure.
Tested auto with 8 wpts flew okay but did have a noticeable twitch at each wpt. Not horrible but not smooth. Seems about like it was in the older firmware. I have EKF off does this need to be on to realize the improvements in 3.2?
My yaw behavior in missions is totally inconsistent. I have the WP_YAW_BEHAVIOR parameter set for follow GPS course. So it should be pointing ahead all the time. I make a mission with spline waypoints, say 10 of them. It flies the plan nicely, but the yaw is never doing the same thing. Sometimes it follows the GPS course. Sometimes it just points "over there". Sometimes it points at the next waypoint.
The same happens when I use ROI. It will start off looking at the ROI. THen end up off in la-la-land.
Why would this happen? I'm using the RC5 beta.
Hello everyone, my apm has once again freezer in flight, falling 7m do not understand why. We are off again all 4 engines for no reason, can someone give me a hand?
LOG:
https://drive.google.com/file/d/0B6QJRmFQmku9djcxTlpLOEpCRzQ/edit?u...
Log_bitmask for Pixhawk.
Where is the best place to look to find the current up to date bitmask info fro 3.2-rc5 ?
What's in Mission Planners parameter note didn't result in what I expected today.
Or even better, can somebody confirm what the bitmask value for logging everything is currently ?
Martin
MP might have an error in the note. Says 6146 is 'nearly all', but I think it might be more like 6142.
Don't forget the minus in front of the 6142 figure...
If you forget you will not get the full set...
LOL. The penny drops. The minus in the notes is on the previous line, not in front of the value. I guess there was a space between and word wrap separated them.
So the bitmask is a 2's complement value type ?
If it is 2's complement like it seems to be it would be nice to have that said in the Mission Planner note text. I've only used or created bitmasks before that were unsigned type and assumed that is was unsigned also.
Martin
169
170
171
172
173
of 262 Next
