Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
I almost always take off in alt hold and have had no problems. Much better than it used to be. I sometimes even fly in my basement and trying alt hold on take off could be a real hair raising experience. Now it just works perfect. I have been flying with EKF all the time as well. Seems very smooth.
I'm using rc12 and had a strange happening yesterday. I have the onboard video and also put up the DataFlash log on droneshare. I was in stable mode except for an RTL because of out of range and then I think it tried to do another RTL because of loss of signal but instead of climbing it lost altitude. I was too close to the ground to do much but I hurriedly switched to stable but then it was too late. Nothing damaged as it was close to the ground and my freshly cut horse grass dampened the impact :)
The only thing I can think of that might have caused it is my throttle was near minimum as I was in stable mode and descending fairly fast. When it switches to RTL, is the throttle completely ignored? I would think so but it seems because I was at about 15% throttle that it was working like PosHold. Doesn't make sense but I can't think of what else would have caused it.
Here is the droneshare DataFlash and also onboard video.
http://www.droneshare.com/mission/24010
The crash is at 7 minutes in the video. Very lucky landing!
https://www.youtube.com/watch?v=sKYDznf4iBI&feature=youtube_gda...
This is one of 100s of flights without issue so I'm curious to know what caused it!
Not related but I noticed from droneshare that one of my parameters was out of range.
MOT_TCRV_MAXPCT is set to 93. I've never modified this parameter but it says the range is 20-80.
Any problem? I'm using simonK firmware if that matters.
and EKF_CHECK_THRESH is set to 2 (I'm using APM 2.5) I know this is a pixhawk only feature so should this be set to 0 or is this ok? The notes don't give a lot of info about it.
Had the same thing happen today. I started to think that it was a battery failsafe condition even though I had that disabled in rc10. I checked the parameters but it's disabled. Then I thought it could be GPS failsafe. I always had that set to LAND but never had it happen since my GPS is usually good. I'm going to upload the log of this flight also to droneshare. How can I see if this forced landing was caused by GPS? For now I've disabled that. Not necessary when doing FPV and pretty jarring when it happens. No matter what I did on the controls, it just kept landing and since I was going pretty fast, it didn't seem to be a smooth landing even though it did land right side up.
Also why do my data flash logs in APM Planner show up with a date of Dec 31 1969 21:00:00 ? Is there a way to set it to the current date time?
Here is the data flash log http://www.droneshare.com/mission/24117
Hi there,
I have some interesting problem with pixhawk 3.2 rc12 firmware.
Everythings is ok and rock solid hovering performance on stabilize mode flying
Im changing mode to altitude hold. Everything is ok. Cool Alt Hold perfomance.
But when I try to switch back to stabilize mode, things go wrong I loose the control and I crash :(
so my problem is switching from altitude mode to stabilize mode.
Yes, I have. I not only lose altitude level. I'm losing all stabilize function
Alp,
Definitely need a dataflash log file.
Hello Randy,
About my upper report, please tell me if it's miss use from my part or if my repported issue could be considered as bug.
Randy,
Crash due to bug in GPS failsafe or Land mode or Geo Fence.
The log attached shows you a flight that I realized in specific conditions:
Takeoff in a valley where there was not GPS (sats 0).
=> Préarm check prevents arming the drone
=> I deactivated pre-arm check
I took off in ALT HOLD, and when the drone took height, it acquired the gps, then it moved very quickly at the max lean angle set (30 deg) against a rock wall and smashed it.
It happens that others like me want to take off from a place where there are no GPS.
To prevent this behavior to other users, you can ensure to disable following functions if the drone does not have a GPS HDOP GOOD when arming:
Also that LAND works only in inertial mode.
And other flight modes using GPS as Loiter only work in flight if GPS HDOP GOOD is reached.
it would be interesting that you explain how GPS GLITCH react when drone take off without gps and when it acquire GPS positions in flight.
43.BIN
75
76
77
78
79
of 262 Next
