ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Today I had 2 flights with 3.2 rc12. Stabilize, Alt Hold, Position Hold, Loiter works great. I have done a complete flight in Position Hold mode. The only problem was when I had switched "Land" mode, the copter descended nicely but after landing it flipped to one side. The motors didn't disarm. I have switched into Stabilize mode and disarmed. So Landing is the only issue, it worked like a charm in 3.1.5.
    2014-10-24 13-30-05.log
      There're excessive throttle fluctuations in your log, check the vibrations in your quad, the land detectors don't like them much.
      • Hi Marco, now that you have mentioned about throttle fluctuations could mixed ESC (simonK & normal) be the cause? Actually one of the ESC went faulty so temporarily I have used non simonk for one motor till the new one arrives. By the way vibrations are under recommended levels.
  • thanx fellow drone flyers for so much of support. i really admire this community. i ran the compassmot. the value was less than 30%. I will now move the GPS 5cm up from the current location and further away form the pixhawk and PDB. i have a 500mW video Tx at 5.8 Ghz. will try to switch off the Tx. but the most probable cause is solar activity because i never had a GPS loss during the past one year i had been flying the same pixhawk and same video Tx. could it have something to do with the backup battery of GPS?
    • I've been doing some bench testing of the GPS batteries on two 3DR GPS/Mag units. They are not new units so maybe not a fair test, but it looks like after a six hour power up (cell charge) I get four or five days before voltage is below 1.4V cutoff. I think the value of series limiting resistor on the cell's charge input might be set for a situation where the GPS is powered on 24/7, not in short bursts like we do. I'm experimenting with a smaller value...
    • This reply was deleted.
      • Great readings!  However, What I don't see is where the battery is located, nor the PDB or ESC for that matter.  Like folks mentioned before, the issue with GPS signal loss may have nothing to do with your electronic interference but rather atmospheric in nature.
        As for the compass next to APM, there use to be one on the board for the APM 2.5 but was disconnected on AMP2.6 because engineers felt the APM's location on the airframe put the compass too close to the PDB and other RFI immitting electronics (BECs, ESC, TX transmitters, etc...).
        It's best the GPS always have a clear look into the sky and the compass placed far enough away from any electronics to mitigage RFI problems which will aid in providing a truer compass reading in flight.
  • Randy,
    About landing detector, I know that it' s set to be threshold below 25% of throttle output...
    I dispose an hexarotor with big motors that for hovering need 30% throttle output.
    By time and for a short time, the drone drops below 30% throttle output, for example 25% (during a squall of wind ..)
    The landing detector never triggered, I want to be sure it can never happen ...
    That you advise me to do to prevent that this can happen?
    It there a way to convince the autopilot it to require 50% power, for example via MOT TCRV parameters or via another parameters?
    Or There is another way to ensure that the landing detector triggers only below 15 or 20%?
    Could you for example add this parameter into the full parameter list or hard code it below 20% ?
    • 3702528661?profile=originalin this screen shot, flying in loiter, you can see thr out droping below 25% !
    AC3.2-rc13 is now available through the mission planner.  I've updated the top part of this discussion to include the changes since -rc12.
    Thanks!
      • You need to click the "Help" tab in Mission Planner and click "Check for BETA Updates" at the bottom of that page.
        PosHold is missing from the "stable" mission planner but is fixed in the beta.
