ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • I increase WPNAV_SPEED normally to 10m/s as well, and have not had an issue with it.
      • Yes, I've flown auto at 35 m/s with no problem, so it's not something wrong with the parameter or program.
  • I have an odd situation. Before I re-calibrated my Hexacopter (running 3.2 and a Pixhawk), I was able to hover  completely level in stabilize mode a just a foot off the ground by increasing my throttle. After I recalibrated the accelerometers, compass and R/C (multiple times), it wants to either pitch forward or backward depending on the calibration when I simply increase the throttle in stabilize mode. I can takeoff to a given altitude and hold steady in AUTO mode, but when I have it LAND, the copter pitches forward and not level. Its almost like it thinks its level, but isn't. Any ideas what may be going on?
  • Hey , can someone tell me what is ERR EKF_CHECK-0 and EKF_CKECK-2 ? I flyed today and on second flight quad shoots up and do flip and props go down to the ground and bam smashed the ground from 60m.
    • Hi, read this page:
      http://copter.ardupilot.com/wiki/common-diagnosing-problems-using-l...
      At bottom:
      16: EKF/InertialNav Check
      ECode 2: Bad Variance
      ECode 0: Bad Variance cleared
      • i'm having the same issue on 2 machines ! both pixhawk
        100% reproducable in alt-hold or pos-hold, can someone explain what this Error exactly means ?
        Bad variance of what values ? any idea how to solve / debug it ? my solution at the moment is to turn of EFK :-(
        or if enable to switch to stabilize and fly manual.
        Thomas
          Without a log it's hard to tell, but if it's the EKF complaining then the heading is likely incorrect which could be a compass issue.  There's some documentation about it here.  Turning the EKF is not a terrible idea if it's not working for you.  DCM+InertialNav is the default for AC3.2.1 in any case.  The only thing is that EKF is generally better at reporting problems than DCM+Inertial nav so it could be a real issue which the vehicle's setup.
  • Without the telemetry radio connect you will not be able to see the error.
    The copter will not arm in Position Hold or Loiter mode with high HDOP also.
    Stabilize and Alt Hold should be fine.
    Mike
  • Hi,
    i use 3.2 quad, i use default settings and done calibration all for my frame. AT home all working great, but if i go outside i have accel error: Accels not healthy. Outside is ~+5 celsius. I thing the error is from low temperature.
    Can you help me?
    • Ficu
      Make sure you don't move the quad for 30 seconds or so when you power it up. I've also noticed by carrying it around it seems to sometimes wig it out and I get that error message. I started to not to power it up until I'm outside first and zi can set it down while it boots up.
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
