ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        • Hi Randy - sorry to pile on but a major concern of mine is the full throttle bug with althold modes during take off. Has this issue been identified and eliminated (tested) ? I'd hate to be stuck in a tree again :D
    • This reply was deleted.
        Steve,
        Based on your previous posts, it looks like you're a new user to arducopter.  That's great of course but you should definitely stick with the nice and stable official firmware which is AC3.1.5.
        The First Time setup wiki is here which might help you get started.
        Alternatively if you have a dataflash log I can have a look at your flyaway issue.
  • 3.2RC4, fly very well.
    Thank you for development staff.
    https://vimeo.com/103391672
    • That is smooth. I was going to wait for a final 3.2, but I'm finding it hard to resist flashing this.
      Anyone been flying rc2, 3, or 4 with a Y6B and APM 2.6? How is it?
  • Is there a list of changes from the latest stable to the 3.2rc4?
      • Thanks Javier!
        Tried to find more information about this:  9) Red Balloon Popper support (Randy, Leonard):
        What is that?
        • Steve: That's a pretty sweet project for AVC where Randy hooked up a periphial computer (I believe a BeagleBoneBlack) with a camera that looked for the red ballons, and when it found them, steered ArduCopter toward it to pop it. Check this out: https://www.youtube.com/watch?v=yRmXwRqPesY
  • Need some help with this one please...
    - Load 3.1.5 (no cal, no wizard, nothing but software load...).  Apply LiPo power, all ESC's beep:  beeep-beeep-beeep - beep-beep - followed by single ongoing beep, all motors wiggle.  Arms and flies normally.
    - Load 3.2-rc4 (no cal, no wizard, nothing but software load...).  Apply LiPo power, 1 ESC beeps:  beeep-beeep-beeep - beep-beep - followed by single ongoing beep, only that motors wiggles.  Arms but only one motor turns.  Disconnect / reconnect LiPo, 4 ESC do beeep-beeep-beeep  (no double beep, no ongoing beep), but that's it...  Arms but motors will not turn.
    - Reload 3.1.5, all operations normal, flies perfectly with no cal/wizard, etc...
    How can software loads affect the ESC in this manner?
      • Alas, I have done both many times, but thank you!  I have calibrated the ESC, per both the "all at once" and the "individual" procedures prior to flying with 3.1.5, and they worked normally, and it flies perfectly.  I did not think they need to be re-calibrated just because I load 3.2-rc3 or -rc4, so I then load 3.2-rc3 or -rc4 and they do not work.  I then reload 3.1.5, without ESC re-calibration, and they work.  If I re-calibrate ESC with 3.2-rc3 or -rc4 loaded, by either method, the calibration appears to work, but the strange motor behavior is still there when I connect LiPo and try to fly.  I am fairly sure the ESC re-calibration worked when -rc3 or -rc4 were loaded because I can reload 3.1.5 without re-calibration after trying (and failing with) -rc3 or -rc4 and the ESC behave normally and it flies perfectly. The ESC simply do not work properly when -rc3 or rc4 are loaded.
          • I tried someone's suggestion, hold down safety switch when applying LiPo power. Did not work. So I tried it re-calibrate ESC all at once. Didn't work. So I tried all at once calibration, holding down safety switch with throttle up to start calibration. Didn't work. So I tried it several more times, each time holding down switch when applying LiPo power, alternating between throttle up and down. ESC never entered calibration mode. Suddenly,once when the throttle was down, it armed and all motors ran! Kept it hooked up, took it out, had my first -rc4 flight, amazing! Have not been able to get it to arm and turn props since... Many attempts to repeat - no go... Might be a race condition in the software somewhere...
