ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • The only thing better than kkflashtool is RapidFlash (Chrome app)..
    • Hello
      I know the problem, it is not the software Simon, K, it is the ESC makes the problems. I fly pixhawk ESC with Simon, K for over a year with no problems
  • Small issue with AC3.2-rc1: I have some pitch twitching whenever I go to RTL. Not much, just short, seemingly periodical twitches. Only pitch, not roll.
    In the attached log you can see that both pitch and desired pitch twitched in RTL. GPS HDOP was fine, no fluctuation there.
    Also, the copter doesn't seem quite as stable as with 3.1.x. On straight descents, it's really noticeable. And even if there's just a slight wind, the copter is not perfectly horizontal in stabilize mode.
    I had to re-autotune and finetune with 3.2 however, and now the pitch PIDs are quite a bit higher than before, and now it's almost a 3:1 ratio between pitch and roll whereas previously it was 2:1. So maybe the problem isn't 3.2-rc1 after all - but I have no clue.
      Fabian,
           Unfortunately I'm getting a 'permission denied' error when trying to download your logs..
      • Randy
        I still have 3.2RC1 on two of my Quads from when I downloaded during the short time it was available. Besides the normal bets risks, any reason why I can't continue testing?
        Thanks JEFF
      • Odd. Let's try that again.
        2014-05-25 19-31-23.log
  • Is there any headway on improving the optical flow?
      Jonathan,
          Not much (although not zero).  We have a couple of pieces of the puzzle but they're not connected.
          The problem with the older mouse-based optical flow sensor is not that there's anything wrong with the sensor but rather that it's never been properly integrated into regular flight modes like Loiter.
          PaulR who developed the Extended Kalman Filter (EKF) with Tridge has the math side of the integration done (i think) so that the optical flow data is incorporated into the EKF but the EKF only runs on the Pixhawk and the old mouse sensor has never had a driver written for the Pixhawk (and the sensors are hard to find now).  So Paul is looking to use the PX4Flow sensor but needs someone (i.e. Tridge or I most likely) to write a driver so the PX4Flow is useable in ArduCopter/ArduPlane/ArduRover.
      • Thanks Randy,
        So what your saying is that for the APM the optical flow is as good as its going to get and all future development for the OF is going on the Pixhawk? (but not using the mouse sensor)
        • To be frank.. I feel the optical flow sensor is old business with the coming of the LIDAR-Lite sensor.  I think however that the DEVs should roll the Sonar, Optical Flow and LIDAR into one ticket and develop support which covers all three hardware options.
