ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        • Henri,
          no, I don't have such a "fly the kids over town" copter who is sucking so many amps :-)
          With my 2.5kg I only consume 13 to 14 amps at all.. But sounds like you are doing great.
          • Christian,
            I guess you were thinking of this quad? LOL (see photo)
            https://storage.ning.com/topology/rest/1.0/file/get/3702825072?profile=original
            • Henri,
              yes something like this.. lol
      • X8R is s.bus receiver, so maybe is it the problem with pixhawk ppm input ? Apm use internal ppm encoder, but it have no lag on rc commands (roll, pitch). Maybe it is the problem with new rc_feel process ?
        Can someone explain ?
  • i think all those fine tuning the PIDs of copter must put a dummy load of gimbals + camera before they begin tuning. the PIDs would be different with and without camera specially THR_MID and to some extent roll and pitch P because the expected camera weight being below the CG of craft. this would save a repeat of tuning flights after installing camera and gimbals.
  • Hello to the DEVS and Testers,
    I have a question for you. I have flown my quad on SW Revs 3. up to 3.1.5.
    All have flown well for me. However, there is a bug that is driving me crazy that I can't figure out.
    The quad flys perfect in all modes. Then I attach a lightweight gimbal and gopro. Now, in loiter it wanders around and bounces up and down in altitude and twitches. I've played with the loiter pid sand no joy. I've CAL'd the compass, no help. I haven't been able to auto tune or compass mot. Do I need the power module installed for compass mot? Auto tune would require dis-assembling the quad (Quanum Nova)and rewiring it.
    Will 3.2 help?
    I see folks mentioning how stable 3.2 is but they don't seem to be testing with the extra weight of a camera and gimbal.
    Thanks for all you guys do for the community.
    Don.
    • Sounds like your THR_MID may not be set right with the added weight of the gimbal and camera. Might be worth a shot to tinker with it. Instructions here:  Setting Throttle Mid
      • Thanks Michael,
        I will give that a try when the new frame arrives in a few weeks. I had a catastrophic crash the other day. I'm pretty sure it was my fault.
        Do you know if I need a power module installed in order to do a Compass Mot?
        Thanks again.
        Don.
        • No for compassmot you do not need a power module, BUT you will get  a more "accurate" result if you have one.
  • Randy,
        I saw have some problem about message is "Bad Gyro Health" on Mission planner is every time when first armed only with 3.2-rc2. I don't know it is a bug or not? But, I still can nice flight is no problem.
