ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
              Ok, thanks for confirming.  This must be a droid planner issue then so could you raise it on the DroidPlanner issues list?
              The fact that it persists across reboots of the flight controller really shows that it must be in teh ground station.
              Txs for the report, hopefully Arthur can sort this out.
            • this is also possbile i was testing both too.
      • yep can confirm same here.....
  • Congratulations (not) on this thread now running to over 200 pages,  fascinating in their diversity of subject matter and overall stream-of-consciousness structure, and a reminder that the only way to find anything within these forums (and so-called blogs that aren't actually blogs) without going sleepless and eventually blind is to search from outside the site, using Google, with the syntax
    diydrones.com: findthis
    For example, the search term diydrones.com: pixhawk tarannis Tx
    returns 16,000+ hits, rather a lot but if that's what you're looking for it's one hell of a lot more fruitful than slogging through the foggy swamps of forums and "blogs".
    • Might suggest you place your concern out in the main Blog Post vice in this one?  You have a valid point and it's not necessarily being viewed by everyone but just this group.  I'm sure others in other groups and discussions feel the same way.  Just my two cents on the topic.
  • Hi Peter,
    Please upload a log, it will  help you see what happened but could also help other users if they have a similar problem.
    Generally with each release candidate (RC) the issues will get smaller and smaller until none, I would advise uploading the log and staying with RC11 until RC12 is released some time soon. By the time you get your parts 3.2 will probably be ready to go!
    Or fly with 3.1.5 which is the "stable" version at the moment.
    • Hi Brandon,
      the 3.1.5 version will not work for me. Okay, it works but i have to use a ppm-encoder. This is the copter:
      http://netzfunker.de/h4680.jpg
      The very short crash-log is attached.
      Yesterday i deleted my first post here because i found the download-Section for previous versions.
      This copter flew very well with rc9.
      Thanks for response.
      Peter
      2014-10-09 17-05-52.log
  • Randy, what was the hash # of RC5 ? and how I can download the source code of AC3.2RC5 from Github ?
