Hopefully someone can help out here.
I am trying to switch from FrSky D8R-II Plus to a D8R-XP so that I can use CPPM.
I previously had six flight modes configured in my Turnigy 9X.
Now that I have connected the new RX and tried to use it I see that both channel 5 and 6 are moving.
This is preventing me from getting my 6 flight modes.
Does anyone know how to configure this combination to get 6 flight modes.
I do this with a few APM-based systems. All of them are connected to Taranis radios, not 9X, but if you load OpenTX, the code should be very similar. If you have audio, they will even announce flight modes.
I use D4R-II receivers on my APM-based multirotors since I don't need OSD RSSI due to having it on vocal alarms in the Taranis. I always use CPPM with APM. I don't think that's your issue. Whatever solution you're using to generate the 6 positions in your TX must be affecting both channels 5 and 6.
My config file for Taranis is here:
http://rcsettings.com/index.php/viewdownload/6-multirotors/33-arduc...
Was there any solution ever found??
