Can you get 6 flight modes with FrSky CPPM
Hopefully someone can help out here.
I am trying to switch from FrSky D8R-II Plus to a D8R-XP so that I can use CPPM.
I previously had six flight modes configured in my Turnigy 9X.
Now that I have connected the new RX and tried to use it I see that both channel 5 and 6 are moving.
This is preventing me from getting my 6 flight modes.
Does anyone know how to configure this combination to get 6 flight modes.
  • I do this with a few APM-based systems.  All of them are connected to Taranis radios, not 9X, but if you load OpenTX, the code should be very similar.  If you have audio, they will even announce flight modes.
    I use D4R-II receivers on my APM-based multirotors since I don't need OSD RSSI due to having it on vocal alarms in the Taranis. I always use CPPM with APM.  I don't think that's your issue.  Whatever solution you're using to generate the 6 positions in your TX must be affecting both channels 5 and 6.
    My config file for Taranis is here:
    http://rcsettings.com/index.php/viewdownload/6-multirotors/33-arduc...
    • Thanks for the reply.
      Yes i know opentx will resolve my problem, but to do that i would have to update my turnigy 9x firmware(i have the v2 firmware). And i can only do that by buying extra hardware which i don't think it is worth it. Might as well sell my turnigy 9x and buy a taranis.
      I would like to resolve this problem without having to spend extra money.
      There has got to be a solution for this problem.
      • any luck with this. Same problem .
        T9x stock fw that I don't want to upgrade because I am having this problem because of upgrading the rx.
        frsky module + d8r xp  upgraded to the 27ms fw for cppm.
        I used to have ch 5 not plugged , ch 6 plugged into ch 5 on the rx I believe.
        Now I have 2 modes instead of 6. And I cannot figure out how to change it in arducopter. There is no fltmode_ch
        • Was there any solution ever found??
          • I got tired of messing with it. I dont use cppm now. pwm and zero issues and all is good in the hood.
  • Maybe this will help? Not sure if it's the same issue.
    http://diydrones.com/m/blogpost?id=705844%3ABlogPost%3A1001090
    • Thanks but that doesnt help my problem.
      The link you gave me is to update to 27ms and to allow the usage of ppm-sum(CPPM) and i did that.
      When i had normal ppm with all the servo wires connected. channel 5 worked fine and i could use it with a mix to use 6 mode on turnigy 9x but now with cppm using one servo wire and the same configuration it changes channel 5 to 6 in the apm planner.
      So to sum it up you need to use channel 5 for 6 mode switch and it doesn't allow you to do that.
  • Did you fix the problem i am also having the same problem. :(
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Monday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Thursday
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
