Cesna Pixhawk Crashed in FBWA . Autopilot wrong???
Hello everyone.
Today I tried to fly a small Cessna 182 with pixhawk and everything seemed fine until I activated the FBWA mode. I started flying manually and take off  with difficulty because it is a little heavy, but when I thought   was stabilized I activated FWBA  and the aircraft went crashing to the ground. Reviewing the log I see that the commands I was sending to pixhawk were completely contrary to what I was doing with my radio.
I'm right ?? below the flight logs to see if someone can help me.
Thanks in advance
2014-09-04 12-04-44.bin
2014-09-04 12-04-44.kmz
  • Hello to all!!!
    Here is my parameter file is someone is interested in Pixhawk on a Cessna 500 Class
    Parametros Cesna Rev 1B.param
    https://storage.ning.com/topology/rest/1.0/file/get/3701881986?profile=original
  • Here it is!!!!!!!
    Working!!!
    http://youtu.be/jNy_vxHcPu8
  • Hello Everyone:
    I'm trying to find out what happened. I would love for someone with more experience could help me with the interpretation of LOG flight.
    What happened was that after flying a bit in the AUTOTUNE mode switched to FBWA mode. Everything worked as it was supposed to and I decided to move to AUTO to fly a mission that was previously loaded.
    When I lost sight of the plane I moved a bit but I could not see what was happening. I put it on again FBWA manner and under the log indicates the airplanes being inverted turned around, ending finally hitting the ground.
    The weird thing about this is that so FBWA could not exceed 40 degrees of roll !, so do not understand how she turned
    Here are the links to log telemetry and video screen mission planner.
    https://www.dropbox.com/s/bmpcjpddyqjw28b/Crash%20cessna%20500%20co...
    https://www.dropbox.com/s/4lp3r75o8imksp0/2014-11-02%2015-15-20.bin...
    https://www.dropbox.com/s/qw2a41f0vh2gsu6/2014-11-02%2015-15-20.log...
    Thanks in advance
    3701867203?profile=original
    Dropbox - Error
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
  • Sorry about your crash...Your not alone, same thing happened to me with my first APM. Plan on "tinkering", sometimes you can get lucky and find a good parameter file for your airframe and sometimes you have to start from scratch. Its taking me about three weekends now to get my new ArduPlane tuned to my liking.
    I've put together a couple planes (and copters) using the APM and Pixhawk...and every time I still get very nervous just before flipping the switch into an AP mode. Altitude has save me so many times.
    Good Luck
    • Thanks. Have you see my log?? Its there another problem that I haven't notice?
  • two major mistakes here:
    1:you tried to blame it on the "autopilot"  - Just realize that until you are very familiar with this advanced piece of technology, any mistakes, crashes, and failures are most likely to be a user error.  :)
    2: you must set up your pixhawk so it's output is *correct*  ,  instead of just setting up your radio so that it flies in manual and hoping autopilot will "guess" corect actions.  Simply said: the autopilot was set up to use the elevator in opposite direction of what's up - when it wanted to go "up"     - set Stabilize mode, and check control surfaces movement on ground.
    • Andre:
      This happen again. This time I did every thing by the book and gess what???
      Just when I change to FBWA, the plane rotates uncontrollable. I went back to manual to try to save the day but it was too late. The plane smashes into the ground.
      I do Check all the control surfaces in manual and in FWBA mode
      Any Ideas.
      Here is my log
      • I see no new log.
        but the question remain: did you set it up correctly ?
        If it flies in manual:   switch to manual, hold plane in hand, apply left aileron, - observe deflection that you do.
        now switch to stabilize,  - roll plane to left , what does the ailerons do ? - do they work against that roll, or do they the opposite of what you would have done to stop it from rolling left ?
        test the same for pitch, as I am not sure if you actually mean roll or pitch , or both are inverted.
        • switch to manual, hold plane in hand, apply left aileron, - observe deflection that you do.
          That's what I do: When I apply left aileron the right Down left Up
          This is a litlle video with the issue:
          https://www.dropbox.com/s/83g35tlhhhfrz2l/Comportamiento%20Pixhawk%...
          Dropbox - Error
          • It's like I thought; your roll response is inverted.
            you must get your ELEVON_MIXING right.
            Basically: you must set up the plane so Pixhawk's output are correct in stabilize, and then, and only then, set up your RC so the RC does what you expect in manual mode.
DIY Robocars via Twitter
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Saturday
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
