Cesna Pixhawk Crashed in FBWA . Autopilot wrong???
Hello everyone.
Today I tried to fly a small Cessna 182 with pixhawk and everything seemed fine until I activated the FBWA mode. I started flying manually and take off  with difficulty because it is a little heavy, but when I thought   was stabilized I activated FWBA  and the aircraft went crashing to the ground. Reviewing the log I see that the commands I was sending to pixhawk were completely contrary to what I was doing with my radio.
I'm right ?? below the flight logs to see if someone can help me.
Thanks in advance
2014-09-04 12-04-44.bin
2014-09-04 12-04-44.kmz
            • Thanks Andre:
              Here is a link to a video, so please you check and let me know if this time is correct
              Thanks in advance.
              Dropbox - Error
              Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
              • Dear Andre:
                Here is a link to a video with the behavior of the elevons. Could you please clarify if it is appropriate, taking into account the limited one of the elevons in response to the Pixhawk roll movement.
                I do not wanna crash again.
                Thanks in advance
                Dropbox - Error
                • yes, that's correct.
                  now, the second step: set up RC pitch/roll reversing to work correctly in manual mode.
              • This reply was deleted.
                • Thank you MarkM
                  This is how stayed. Video
                  Please let me know if the problem is now solved.
                  Dropbox - Error
        • When I checked the plane FBWA, if the nose down the ailerons moved reverse to rise again. the same for lateral movements.
          I filmed a video with it.
          Here is the log.
          2014-09-23 12-42-26.rar
          • "moved reverse"  ?  - are you trying to say it's working correctly or wrong, if wrong (which I am pretty sure of)  then you need to do what I wrote in "2:"  two weeks ago or so.
            • I'm sorry by my poor English.
              Please see my video
              https://www.dropbox.com/s/83g35tlhhhfrz2l/Comportamiento%20Pixhawk%...
              Dropbox - Error
              • Hi Wilson,
                As Andre has tried to explain, in FBW mode you need to reverse the ailerons, in the second half of your video, when you change to FBW mode, when you roll the pixhawk to the right the left aileron should go up, and the right one down, to level the plane, you have this reversed at the moment.
                • The Pitch Movement it's ok or is it inverted too???
                  thanks
