Coaxial-Setup with Arducopter
Hey,
will Arducopter eventually support Coaxial setups, such as the Y6 or an X8?
Because i am planning on designing my own Coaxial-Copter running on the APM-Hardware.
Regards
Daniel
  • Was this ever answered? Im also buildings X8 coaxial and want to know how to set up the GCS software or which others will work
  • Yes, my Y6 is happily flying, as the ACM 2 Codes support y6 coaxial setup...
  • Hi Daiel,
    Have you made any progress?
    Cheers,
    Scotte
  • Hi,Im planning to build one too. Upgrading Quad to X8, any diagram pm me.TQ
  • hi can some tell me the pro arrangement order for arducopter x8 with the present stock code
    Hi Daniel,
    You can do a coax X8 right now with the stock code if you use a 'Y' servo cable and 2 ESCs per arm.
  • I have an X8 that is flying http://www.diydrones.com/profiles/blogs/arduoktokopter-flies
    Peter
  • it's basically a mixer setting
    so yes, it will support it
