Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Simple test flight with autotune on Y6B - tuned parameters are not usable - reverted to manually tuned.
    What is changed by Autotune_aggr and Autotune_Axes? What are recommended values?
    3701981955?profile=original
    2015-04-14 10-23-03.zip
      Hi Hubertus,
      In exactly what way is it un usable?
      Autotune_aggr is a parameter that sort of defines the noise rejection of the autotune. It should have been 0.1. Autotune_Axes is a bit mask to define what axis will be tuned. 1 is Roll, 2 is Pitch, 4 is Yaw, 3 is Roll and Ptich ect ect.
      You have the same a similar problem I am seeing with others (but not enough to stop you getting what looks like a reasonable tune) and I hope the next release will fix this.
      • Leonardt,
        tried again flying with the autotune parameters - it´s flyable, but there is some overshoot and oscillations in roll. Rate P/I pitch is out of range according to MP - is this a problem? Response in pitch axis is quite good, so perhaps i should leave it to the tuned params.
          Hi Hubertus,
          Oscillations is definitely bad. But it is strange as tuned pids seem to be more conservative than your original pids.
          If you could try the autotune in the next release for me I would really appreciate it!!
    wow - thank you very much to all the developers!
  • Thanks Randy. My 4 Year old Daughter is into everything. Have had to lapse a little with playing the devs builds in the park. Have a pix and am looking on adding a second GPS. Maybe the Neo 7 as a redundant backup? Humm..
  • Loaded 3.3 today, previous 3.2.1  flies fine in PosHold but with 3.3 I got error (Flightmode err 16) and PosHold is not working
    Loaded 3.2.1 back and it is rock solid in Poshold.
    I did not change anything between the 2 versions
    Log from 3.3 attached 2015-04-13 19-18-15.log
    Log from 3.2.1 attached 2015-04-13 18-38-21.log
    Did this (Note #1: because of the accelerometer range change (see 6b below) this upgrade will require the vehicle's accelerometer calibration to be done again.)
    Logs zipped
    logs.zip
  • APM Planner won't calibrate accelerometers after 3.3
    I screwed up and started a discussion instead of a reply so copied to this discussion
    I am pretty sure this was caused by the 3.3 upgrade.  I have successfully calibrated the accelerometers many time recently and when I tried after 3.3 it times out and will not calibrate.  I hooked up my trusty Iris after several attempts on my 550 and the Iris responded as normal.  I then hooked up a spare pixhawk and uploaded 3.3, attempted a calibration with no results.  Neither unit will calibrate now even if I revert back to 3.2.1.  I took the 550 to School today and successfully calibrated 3.3 with a PC running Mission Planner.  I came home this afternoon and uploaded 3.3 to my Iris and it now has joined the other two in the calibration fail pile.  I am now out of tricks and could use some help.
    RB
