Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
- 8-bit dropped, 32-bit+ only
- mainstream linux support (new for 3.3?)
- EKF, EKF, EKF
- SOLO support
surely worth a major version bump - if not for this, then what :)
There is a good argument for bumping up the version, some others on the dev team are keen to do this as well but personally I like the idea of saving the major version bump for what you mentioned which is the main stream linux support. It's almost there but I think it's still a fork of the main code. Certainly there are a bunch of (non-critical) features that don't work on the Linux boards yet but more than that we really haven't sorted out an easy way to load firmware onto the linux boards.
Also ideally I'd like to bump the version up in coordination with Plane if possible... and their move to Linux would happen at the same time because we share so much of the same code (most of the libraries)
Randy, you have a good point here.
As my main job is a software project manager I think there is a need to somehow clearly distinct the two versions. As MS (and others me included) do when there is not enough reasons for a major version change, they name it X.5,
IMHO a 3.5 version would be a clear enough distinction over the 3.3.
Just my 2 cents.
In my opinion, the fact that it runs only on fast CPU boards is enough to make it a new major version.
So it would be clear for everybody, versions up to and included v3 are APM and PX compatible, v4 and above are only for PX boards (any future fast CPU board).
HI!!
AC test 3.3 rc1 continued. I changed the parameters of the ATC and Autotiun the following
ATC_ACCEL_P_MAX, 110000
ATC_ACCEL_R_MAX, 110000
ATC_ACCEL_Y_MAX, 36000
ATC_RATE_FF_ENAB 1
AUTOTUNE_AGGR 0.1
I waited for nicer weather and turned autotiuna. This time is flying almost perfectly, yet I did not have as nice a flying koptera after autotiunie without making changes to the settings, the yaw no jumps, no overshots in pitch and roll. In Poshol is flying nice does not swing when falling. I do not know if I now fly on these new parameters ATC if I change them to Basic? I have a problem with the compass do not know why I Large change in mag_field. I use GPS Drotek Ublox M8N, HMC5983 compass. Calibrations passes, nicely years well, compassmot made, have any ideas on what I am doing wrong ?. For earlier versions of AC was this error sometimes and sometimes not
And my Log for inspection Log
I´ve tried the 3.3 rc1 (5a4039d9) with AUAV-X2 and Drotek GNSS M8N XL @ my F450 and its working great in Stabilize, Althold, PosHold and Land. Used my former settings of 3.21 and did a new ACC Cali. No complaints so far. Mission Planner Log Analyser (1.3.24) didn´t show any errors anymore like it used to @ former versions, despite normal behavior.
Surprizingly, the shown values for the MAGFIELD are low as they never were, despite same MAG and Copter location, without even doing a new MAG calibration... Used to be around 520- 550 , now slightly below 400, well...
Which hardware setup?
Hi Marco.
I'm assuming you're asking what type of airframe and flight controller?
It's modified 3DR Y6B with Pixhawk. The motors are 690kv running both 1247 and 1347 props. Also have two GPS units on it. Primary is the Neo-M8N GPS only with the Secondary on mast of the Lea-6H and compass. There is also a FPV camera and transmitter on the frame.
Randy,
Today I flew the Y6B in Loiter for most of the flight. There was a small breeze with minor gusts.
I powered up the drone and let it sit until I heard the GPS tones, then lifted off initial in Alt Hold but noted it was drifting so I selected Stabilized and forgot the throttle was up around 80-90 percent. So she launched upward and into the breeze which I jumped on and steered it back to my yard. At this point I brought her down to just feet from the grass and put it into Loiter. For the most part the copter stay in the yard area, but I noted it drifted off and on, probably due to GPS accuracy. I also noted that she wouldn't hold altitude and a couple times I had to give more throttle to get it off the grass and back into a higher altitude (roughly 10ft). The remainder of the flight time, she behaved and landed without incident.
But the is questions pertaining to the amount of errors I saw when I downloaded the log (see attached). I'm not sure how to read this part but I noted Err codes.
Err: EKF_CHECK-2
Err: FLIGHT_MODE -5
Err: FLIGHT_MODE -16
Err: EKF_CHECK-0
Note sure what to make of these codes. Could you explain what I'm seeing and if this is of help to you Devs?
2015-04-20 17-01-32.zip
427
428
429
430
431
of 449 Next
