Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
That's great Randy thank you! I changed the foam under the FC - I think it's to firm. Will double check the props too, assumed they will be good as they are pre-balanced T-Motors.
Thanks again, looking forward to the final release of 3.3 - Cheers
Re: b) increased accelerometer range from 8G to 16G to reduce chance of climb due to high vibrations (requires accel calibration)
I have a 250 which had some serious altitude stability issues on 3.2. Those problems seem to have disappeared after installing 3.3.
Thanks!
Awesome!
I also have a quad that was a disaster, and is much much better on 3.3.
I will have to try it on my 250 quad
Hi Nate892,
The next release candidate should fix your problem. Sorry about the hassle!!
Hi there,
Im trying to add px4flow(Lucas-Kanade method custom firmware) to pixhawk(3.3rc1) I think, Its work :)
I have two question about that;
1) Can I use Mission Plannner's user items "opt_m_x" and "opt_m_y" for optical flow checking?
2) Which flight mode support optical flow? loiter, poshold, althold?
@Alp,
Yes, optical flow should work although some more changes are coming to make it more reliable. It was demonstrated at NAB with the solo.. it's all the same code.
Only Loiter uses optical flow at the moment but that was a specfiic choice only because it's very new functionality I expect we will extend it to other flight modes like RTL in the future (it's very easy to extend to other flight modes).
Yes, I think the opt_m_x, y should show the raw output of the sensor.
@heliroberto,
It's there, just click the beta firmware's link on the MP's install firmware screen.
Yes, I also see V3.3-rc1. Maybe try updating your version of mission planner. Also you must be using a Pixhawk but that shouldn't matter because the MP doesn't know what board you have when it's not connected.
FYI: You need to be using the Beta version of Mission Planner in order to see V3.3-rc1, otherwise it shows up as V3.2.
Nathaniel ~KD2DEY
435
436
437
438
439
of 449 Next
