Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Hi,
    Great work, thank you! I have a problem but I am not really sure that it is down to the firmware (3.3 -rc1), it was flying well with 3.2.1 but I made a few changes; ESC (New X rotors), Foam, GPS (Ublox 7) at the same time as upgrading. I know the sensible thing is to revert and try again but it started to rain!
    The copter (TBS Disco with carbon arms PIXHAWK and 390KV motors), flies superbly in stabilise but when I switch to any other mode it goes nuts! Up,Down take your pick it does it and fast!!! ;-) Switch back to Stab and harmony is restored.
    Really appreciate some help with this - Cheers!
    2015-04-16 19-24-23.log
      Mike,
      It looks like really high vibration when the throttle goes above 40% so I'm guess a mechanical issue.  In the graph below it's especially obvious at the beginning with the vibration maxing at +3G and -4G.
      3702560521?profile=original
      • That's great Randy thank you! I changed the foam under the FC - I think it's to firm. Will double check the props too, assumed they will be good as they are pre-balanced T-Motors.
        Thanks again, looking forward to the final release of 3.3 - Cheers
  • Why do I get "EKF variance" immediately after arming (trying to arm in stabilize mode)? Led start to blink yellow-red. Even did not fly, just arming on the ground. Is it normal? Small log attached.
    2015-04-16 23-25-37 2.bin
    • Any ideas?
  • Re: b) increased accelerometer range from 8G to 16G to reduce chance of climb due to high vibrations (requires accel calibration)
    I have a 250 which had some serious altitude stability issues on 3.2.   Those problems seem to have disappeared after installing 3.3.
    Thanks!
    • Awesome!
      I also have a quad that was a disaster, and is much much better on 3.3.
      • I will have to try it on my 250 quad
  • Did three auto tunes so far, reduced the suggested atc_accel parameters and the other parameter suggested in this thread( can't remember the name right now, but the one that was 0.5 instead of 0.1) each auto tune, was way too unstable, machine would take off, and wobble violently. last auto tune with the accel parms lowered was the least wobbly. Turned down stab rates by 1/3 and they are now closer to previous settings I had that flew well,( except in stronger winds)
    So far 3.3 seems more solid in position hold.
    Besides the auto tune problems, I can't get loiter and throttle pids to change. I change them, click write...and it reverts back.
      Hi Nate892,
      The next release candidate should fix your problem. Sorry about the hassle!!
