Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • It should be fairly easy to get this working unless you have a setup that I have not considered.
    You want to set your Ch7_OPT (or whichever channel you want) to 29.  29 will not show up in the Mission Planner parameter description until this firmware goes stable unfortunately.  Then, you use that channel to control the gear exactly the same as with any other ChX_Option function.  There is absolutely no connection between the incoming channel value, and the outgoing channel value.  The RCX input PWM is converted into a Boolean "gear up or gear down" command.
    Then, you need to choose which Output channel you will use for the landing gear.  Say you are going to use Channel 9.  Go to RC9_FUNCTION, and set it to 29, which is the Landing Gear function.  (it's just coincidence that these have lined up on 29, normally this doesn't happen).
    Then find LGR_SERVO_DEPLOY and LGR_SERVO_RETRACT.  These are the PWM values that correlate to landing gear up and down.  Set these to suitable values for your mechanism.
    Now, when you set the input switch high, the landing gear should go up.  Switch the switch to the low position, and the gear should come down.  There is also a semi-automatic function, where the gear will lower automatically in Land mode or the final landing stage of RTL.  So if you lose radio control and it does an auto-landing, they should drop automatically.  There is also protection such that, if your gear switch is in the retract position when you boot up, the gear will NOT raise soon as the system is booted. It will be locked in the down position until such time as you lower the switch, then raise it adiydrones.com
    • Sorry for the messy post guys, I'm trying to work out some internet problem on my computer.  I'll fix this up so it makes sense when I can.
  • thx for clarification...
  • Hello friends.
    I've been testing COPTER 3.3 rc1, and I detected two problems.
    The first problem is the continuous variation notice EKF, although in three hours flying this BETA version, had no problems or faults with the EKF filter.
    The problem was flying in drift mode when landing, and disarm engines, quad leaned over and touched the ground.
    I am very satisfied with this version and very grateful for your work.
    best regards
    • This reply was deleted.
      • I am also getting EKF Variance when arming. I was still able to arm and do a short flight in Stabilise.
        @Randy Is it ok to fly with this warning? Are the tolerances too tight or is it indicating I need to change my setup?
          Glenn,
          I think it will be safe while you're in stabilize but it won't let you go into autopilot modes like Loiter, RTL.  So in case of a failsafe it will likely switch to pilot controlled Land.
          I'm pretty sure we have some thresholds set too tight so we're not letting the user into the autopilot modes when we probably could.  All those thresholds changed when we moved from inertial nav to EKF and it also seems like we're not giving as much information about what the EKF is waiting on (it's normally for the EKF estimated velocity to fall).
      • Yes
  • Tested rapid ascents and descents with an over powered 650 quad. It has 3508 580 kv T-motors and a dampened mobius cam (no gimbal). No question 3.3.1 is way more better. The video proves it. The first two descents were very unstable and the wind was light. With 3.3.1 loaded  2 days later the wind was out of the NNE, and pretty strong. Up high in clean air the descents were very stable. The second descent in 3.3.1 was actually in stabilize mode(the caption was wrong) at ~ 8% throttle not touching the right stick, and it was the most stable. Well done Leonard!!!!
    http://youtu.be/n4Bcq2ImsHI
      Thanks Greg,
      It is nice when things work the way they are supposed to :)
      Greg,
          Thanks for testing that.  Indeed the descents in Loiter/AltHold do look more stable using AC3.3.
              place in video when descending with AC3.2.1 is here
              equivalent for AC3.3-rc1 is here.
         What was the WPNAV_SPEED_DN value set to?
