Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Hello,
    I am now testing 3.3. in automode.  I have a question:
    1. Which parameter turns off the sound when switching modes?
    2. How to start automode flight from the ground in MP now?
    Thanks.
      Gleb,
      Yes, sadly no way to mute the pixhawk besides the physical solution.  It's on the to-do list though!
      We currently still require the pilot to raise the throttle to start the motors in any of the flight modes.  I..e you need an RC connected.  The only exception is Guided mode's take-off command.  So you may be able to arm in Guided mode and then, if your GCS supports it, send a take-off command and up it'll go.  Then after that you could switch into Auto.
      Now, the drone-deploy guys have asked that we enable arming and take-off in AUTO mode so we're planning to add that (hopefully before AC3.3 goes out) but it's not in -rc1.
      • Thanks Michael
        Thanks Randy,
        I would like to ask you make parameter that turns off the sound when auto mode. When I check the settings the copter sound is very useful and necessary function. But when a copter on a mission, the sound can be heard a long way, especially when copter is in loiter mode in place long time. All people attention to the copter, absolutly all - people, dogs, cats, all all all.
        I can not turn off the red wire, because I need the sound to the beginning of the mission. I check the state before starting.
        And I will be wait enable arming and take-off in AUTO mode.
        Cheers,
        • Have you tried putting a piece of tape over the speaker to mute it.  You can here it when arming up close, but isn't easily heard at any distance.  I use electricians tape on my birds and it is pretty much drowned out by the prop noises in flight.
    • To turn off the sound you cut the Red wire going to the speaker.
      The copter makes enough noise what's a few more.  It will let you know when something other than you changed the flight mode and if it's not successful it beeps twice.
      It also beeps during auto missions as it hits each waypoint too.
  • Today I had a first mishap using 3.3 rc1. While in Poshold, then switching to land, the Spy Y6 descended and got to about 6 ft. then apparently decided it didn't like the position it was at, twitched, and made a bee line to the cedar trees. I tried to correct as best as possible, but it did crash (gently mind you), and no harm done.
    Ready to blame xxxx, I looked at the logs and there they were, horrible Z axis vibrations. Upon further investigation, one of the Zeal gel pads came loose and the FC was thumping on the mounting plate. I'd been planning on ridding those Zeal pads, and now was forced to. See before and after.
    Before. Note all the spikes. Wow, surprised it didn't crash earlier.
    After removing Zeal and replacing with 3DR pads. Very nice.
    My question is, just how much does EKF help dealing with bad vibrations that may happen suddenly in flight for example?
  • Hello,
    Are there some updates coming for the EPM from Nicadrone?
    Thanks in advance!
    Best regards,
    Max
    • Hello Max,
      We will do an announcement on the EPM soon :D
      • AWESOME!! Thanks for the answer :D
