Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Got an answer from devs on another forum.  Needed to set SERIAL2_PROTOCOL parameter to 3.
    • I'm guessing there might be Mavlink changes that broke any telemetry conversion parts of APM or any other seperate converter (remember those are not supported by the APM team), so the dev of the converter code might have to take a look at it.
  • This reply was deleted.
          Robin,
          Great.  I've updated Note #2 in the main part of the discussion to add the bit about the board requiring a reboot after changing the MOUNT_TYPE.  This seems to be the #1 issue people bump into with AC3.3 so we need to find a way to default that parameter to "1" if the user has been using a gimbal previously.
  • Paul / Zhang,
    Thank you for the really helpful information - when it arrives I will give it a go!
    Cheers, MIke
    • Hi Paul,
      Do you think the onboard sonar sensor will ever be supported? I just wondered if 3DR should be informed as they are selling them still. Funnily enough the eBay far east version doesn't come with the sensor and is a fair bit cheaper.
      Hopefully I will be able to do some testing this weekend if they arrive in time! Thank for all the handwork, I think OF could be a real advantage. Cheers!
  • Hello,
    I am now testing 3.3. in automode.  I have a question:
    1. Which parameter turns off the sound when switching modes?
    2. How to start automode flight from the ground in MP now?
    Thanks.
      Gleb,
      Yes, sadly no way to mute the pixhawk besides the physical solution.  It's on the to-do list though!
      We currently still require the pilot to raise the throttle to start the motors in any of the flight modes.  I..e you need an RC connected.  The only exception is Guided mode's take-off command.  So you may be able to arm in Guided mode and then, if your GCS supports it, send a take-off command and up it'll go.  Then after that you could switch into Auto.
      Now, the drone-deploy guys have asked that we enable arming and take-off in AUTO mode so we're planning to add that (hopefully before AC3.3 goes out) but it's not in -rc1.
      • Thanks Michael
        Thanks Randy,
        I would like to ask you make parameter that turns off the sound when auto mode. When I check the settings the copter sound is very useful and necessary function. But when a copter on a mission, the sound can be heard a long way, especially when copter is in loiter mode in place long time. All people attention to the copter, absolutly all - people, dogs, cats, all all all.
        I can not turn off the red wire, because I need the sound to the beginning of the mission. I check the state before starting.
        And I will be wait enable arming and take-off in AUTO mode.
        Cheers,
        • Have you tried putting a piece of tape over the speaker to mute it.  You can here it when arming up close, but isn't easily heard at any distance.  I use electricians tape on my birds and it is pretty much drowned out by the prop noises in flight.
    • To turn off the sound you cut the Red wire going to the speaker.
      The copter makes enough noise what's a few more.  It will let you know when something other than you changed the flight mode and if it's not successful it beeps twice.
      It also beeps during auto missions as it hits each waypoint too.
