Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Would be great to use it on Serial5
thanks Randy :) Thanks to all the developers!
Hi there,
I think, will Copter 3.3rc-2 be released on tomorrow. I have found some detail about it ;)
1) AutoTune reliability fixes (improved filtering to reduce noise interference)
2) Optical flow improvements:
a) Range Finder pre-arm check - lift vehicle between 50cm ~ 2m before arming.
Can be disabled by setting ARMING_CHECK to "Skip Params/Sonar"
b) Vehicle altitude limited to range finder altitude when optical flow is enabled
3) AltHold & Take-off changes:
a) feed-forward controller and jerk limiting should result in slightly snappier performance and smoother take-offs
b) vehicle climbs automatically to PILOT_TKOFF_ALT alt when taking off in Loiter, AltHold, PosHold, Sport (disabled by default, pilot's throttle input overrides takeoff)
c) PILOT_THR_FILT allows enforcing smoother throttle response in manual flight modes (defaults to 0 = off)
d) TX with sprung throttle can set PILOT_THR_BHV to "1" so motor feedback when landed starts from mid-stick instead of bottom of stick
e) GCS can initiate takeoff even in Loiter, AltHold, PosHold and sport by issuing NAV_TAKEOFF mavlink command
4) Stop flight mode - vehicle simply stops and does not respond to user input
5) Aux channel features:
a) Emergency Stop - stops all motors immediately and disarms in 5 seconds
b) Motor Interlock - opposite of Emergency Stop, must be on to allow motors to spin motors, must be off to arm
6) Air pressure gain scaling (of roll, pitch, yaw) should mostly remove need to re-tune when flying at very different altitudes
7) landing detector simplified to only check vehicle is not accelerating & motors have hit their lower limit
8) Loiter tuning params to remove "freight train" stops:
raising WPNAV_LOIT_MAXA makes vehicle start and stop faster
raising WPNAV_LOIT_MINA makes vehicle stop more quickly when sticks centered
9) Other items:
a) faster EKF startup
b) Camera control messages sent via MAVLink to smart cameras.
Allow control of camera zoom for upcoming IntelEdison/Sony QX1 camera control board
c) Lost Copter Alarm can be triggered by holding throttle down, roll right, pitch back
10) Bug fixes:
a) Home position set to latest arm position (it was being set to previous disarm location or first GPS lock position)
b) bug fix to mission Jump to command zero
Latest development release notes always available (publicly) here: https://github.com/diydrones/ardupilot/blob/master/ArduCopter/Relea...
I would guess the devs (who are very open and active here) do internal testing on this and announce it when they're ready.
There is no secret here https://github.com/diydrones/ardupilot/commit/77c2991867913b0478815...
Last night, I upgraded to AC 3.3 (compiled from master). I calibrated the accelerometers. I can arm and the Iris+ responds to throttle, pitch, roll input from the transmitter (props off). The problem is that on my transmitter, I no longer get updated values for Sats, Battery Voltage, Flight Mode, etc. All show 0 (except for flight mode, which shows Stabilize). I can change flight mode -- the drone responds with a beep when I move a mode switch -- but no change in the display. I reverted to 3.2.1 and, as before, the values update properly. I then installed 3.3 downloaded via MP. As with the version I built, the flight data values are all 0. I didn't see any other mention of the issue in this thread so I assume I'm doing something wrong but I don't know what. Thanks.
Got an answer from devs on another forum. Needed to set SERIAL2_PROTOCOL parameter to 3.
I'm guessing there might be Mavlink changes that broke any telemetry conversion parts of APM or any other seperate converter (remember those are not supported by the APM team), so the dev of the converter code might have to take a look at it.
I'm trying to configure 3.3-rc1 to take advantage of the new gimbal control features with my alexmos 8bit board running 2.3 on a DYS gimbal. Excited about trying out the do-mount commands.
After hours of fiddling I can't get the gimbal tilt control to work at all via RC10 (aux 2) and remote input via RC6 via setup in the latest version of mission planner.
Testing using an analog servo and I can't get the servo to move using inputs from the remote. I know the servo rail works because I have a retract setup on RC9 (aux1) and it works fine.
Any suggestions/tips on getting the pixhawk to output gimbal tilt signals either from the mission or via the TX?
thanks, robin
Read some posts back and you wil find the solution.
