Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • I appear to be unable to calibrate the accels, every time Bad AHRS and the horizon is wandering. Board and settings are working fine on 3.2.1.
    My board (AUAV-X2) is installed upside down, and as the accelerometer is backwards I normally use AHRS_orientation = 8. I have tried a few orientations now, all with the same result. is it possible AHRS_orientation is not being honored correctly?
  • Tryin 3-3-rc3 on small 600mm CF quad.
    - Could not calibrate accelerometers on the table using radio link. Was successful using USB link first go. ??
    - Compass calibration even with 2,500 + points didn't "auto accept" (using radio link)
    - Radio calibration using Taranis and "native" channel order (e.g. Throttle on channel 3 instead of normal 1) was easy through radio link.
    Using Quanum telemetry, I did disable on board failsafes related to battery..
    Flying test:
    Take off was smooth and easy in stabilize.
    Moving on to ALT Hold was very good.
    As soon as I changed to loiter, the quad decided to go where he felt better and crashed.
    Perhaps someone could tell me more about it looking at the attached bin file?
    Thank you in advance.
    Henri
    • Bin file didn't upload..
      2015-05-09 15-30-50.bin
      • This reply was deleted.
        • Using M8N
          Not sure:
          - Mission Planner 1.3.25.3 and 3.3-RC3 (11th May 2015)
          - Shielded audio cable in between the Pixhawk and the M8N (no more noise on SDA line)
          compass calibration was really easy. and both internal and external were showing on the nice "calibration balls"
          Accelerometers calibration went fine with radio link. (no need to use USB to do so now)
          After powering it off and back on, after calibration,  the altitude was correct!
          So it does looks promissing..
          Henri
        • Good morning Geert.
          Using this one: M8N. But after the crash, I decided to investigate the compass side. So I connected an oscilloscope onto the SCL and SDA lines (directly on the little tower 15 centimeters above the Pixhawk) to see if anything was not correct. Well even the I2C clock line looks ok the I2C data line (SDA) is very noisy and small spikes are very visible on the scope.
          Now running each SDA and SCL line on shielded audio cable to improve the noise margin. I am surprised as normally 400 pF is possible by the I2C standard. Don't know where this "coupled noise" is coming from.
          Henri
              Please reference section 7.5 of http://www.nxp.com/documents/user_manual/UM10204.pdf
              7.5 Wiring pattern of the bus lines In general, the wiring must be chosen so that crosstalk and interference to/from the bus lines is minimized. The bus lines are most susceptible to crosstalk and interference at the HIGH level because of the relatively high impedance of the pull-up devices. If the length of the bus lines on a PCB or ribbon cable exceeds 10 cm and includes the VDD and VSS lines, the wiring pattern should be:
              SDA _______________________
              VDD ________________________
              VSS ________________________
              SCL _______________________
              If only the VSS line is included, the wiring pattern should be:
              These wiring patterns also result in identical capacitive loads for the SDA and SCL lines. If a PCB with a VSS and/or VDD layer is used, the VSS and VDD lines can be omitted. If the bus lines are twisted-pairs, each bus line must be twisted with a VSS return. Alternatively, the SCL line can be twisted with a VSS return, and the SDA line twisted with a VDD return. In the latter case, capacitors must be used to decouple the VDD line to the VSS line at both ends of the twisted pairs. If the bus lines are shielded (shield connected to VSS), interference is minimized. However, the shielded cable must have low capacitive coupling between the SDA and SCL lines to minimize crosstalk.
            • Hi Geert.
              Ferrite rings are more (or less) not  good news for the flight controller mag sensors.
              Yes I used plain small shielded audio cable and that did improve nicely the spikes on the SDA line of the I2C bus.
              I guess a twisted  pair cable of ground + sda signal should do an equivalent task.
              No matter what it isn't a good idea to have relatively fast signals traveling long distances ( 10 centimeters or more ) without a ground data signal in between them.
              Henri
      • I'd like to try some Aeronaut Carbon Light props, but none to be found in the U.S. :(
        So you think it's an issue with RC3? You say "default" PID's, are you going to try Auto Tune on RC3?
    • Do you have a list of the build?
