Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Stephan,
It's close but not exactly the same. It's got a couple hundred commits extra many of which will make it back into master for AC3.4. There are a few things that are very Solo specific that may never make it back into master but it'll all be published shortly - legally it must be published once people start receiving their copters.
Is terrain following supported by 3.3? As we switch from photogrammetry to lidar, terrain following is much more appropriate for scanning. If this is the case, can Lidarlite be used as a backup if your loaded SRTM data is a little off lol? We've got some really big trees around here...
AFAIK, it should be in 3.4 not in 3.3
I'm also eager to have it, as I mostly fly in hills, with lot of big trees...
"APM:Copter V3.3 RC5" and "DYS Marcia 3-axis gimbal for GoPro 4", all the details in the video description.
Here the raw video file: https://drive.google.com/file/d/0B3HEcrNCOga9bGVId3c0ckU2R1E/view?u...
Is your PixHawk enclosed ?, as you don't seem to have any dropping in altitude due to the high speed you are moving over the grass...,
I guess you are forward flying with camera looking backward, or is the front of the PixHawk pointing in the same direction as your camera ?
Erik
Very nice clip marco...
No doubt this has been explained a number of times, but can someone explain the difference between Rcin an Rcout under CTUN? Why do they diverge? Is there a dead zone in AC3.3 that causes this. When determining tx throttle position, isn't Rcin what is actual physical position of the stick? IOW, if the stick is in the middle (no curves etc.) is Rcin the one to use for position @hover?
RCIN is the pwm input from the receiver, RCOUT is the pwm output, for the ESCs/motors.
Regarding your question no, the throttle_mid is a number that can go virtually from 0 to 1000, and the center is 500, while the pwm input usually ranges from 1100 to 1920.
I'm looking at the code for 3.3 and it says that for serial ports: 2 - DPort and 3 - SPort
The wiki says that it's 3 for D Port and 4 for X Port.
The full parameter page says it's 3 - DPort and 4 - SPort.
Which is it or is it none of the above?
Hello,
i can not upgrade my Firmware. I always get this message:
