Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • No, your not alone on that. Sometimes I've used the reset button on the Pixhawk to get around this instead of yanking the USB cable out and back in (IIRC) ...
  • Hi Randy and Paul Riseborough.
    I'm testing 3.3RC5 using PIXHAWK and PX4FLOW. And I have 2 question
    1) I have completed all the steps in this guide http://copter.ardupilot.com/wiki/common-optional-hardware/common-op... , but parameter EKF5.meaRng is always 0. In QgroundControl parameter ground_distance changes correctly and is the actual distance to the ground.
    2) I’m set the EKF_GPS_TYPE parameter equal to 3 and trying take-off in Loiter mode. But copter lost YAW control via transmitter and autopilot also cann’t control YAW.
    I read reply zhang xu and all comments  http://diydrones.com/forum/topics/copter-3-3-beta-testing?id=705844... but he hadn’t had same problems.
    Help me please with my questions. Thanks in advance
    2015-06-02 14-56-45 2.bin.log
  • Perhaps this has been already mentioned but I haven't seen it.
    Testing 3.3 RC5: The old TRIM_THROTTLE value which i used to copy in THR_MID isn't available in 3.3 RC5.
    The THR_MID stay at 500. Was wondering which parameter replaced TRIM_THROTTLE?
    Thank you in advance.
    Henri
      Hi Henri,
      We found there was three parameters when their only needed to be one. So to answer you question, Thr_Mid is what you set to your hover throttle.
      • Hi Leonard,
        TRIM_THROTTLE was set by FC, so all we had to do was hover for a while, land and set THR_MID to the value found in TRIM_THROTTLE. Simple, easy. and precise.
        Now we have to look in the logs and approximate the value from the log.
        I miss the old way too.
        • @Leonard: Actually when changing payload it was easy to check if TRIM_THROTTLE had changed a bit or more.. Just a little hover and it was possible to adjust THR_MID.
          Actually it could be done automatically by the FC? (Or is there hidden trap?)
          Henri
            Hi Henri,
            Sorry I lost your reply. I hadn't thought of that as I am always looking through logs. I would personally be happy with doing it automatically. Randy has been careful and kept fixed. We will probably automate it on the next release after a good amount of testing to make sure it is safe.
            Sorry for the inconvenience. I will talk to Randy about it.
  • I'm not able to use the landing gear function in 3.3 RC5, and searched around to find out what could be the problem. I found someone describing exactly my issue in this forum post:
    http://ardupilot.com/forum/viewtopic.php?f=111&t=12519&p=33...
    As there are no replies to the post, I just wanted to mention the issue here so maybe there is a chance that it will be adressed for RC6.
    Best reg.
    Eirik
