Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Adolfo
RC feel doesn't have any effect on Autotune. So there is no problems setting it before doing an autotune with aggr set to 0.05.
If the end result still vibrate then you will need to manually adjust the tune by dropping the values until it goes away.
Hi Pomaroli,
Looks good to me. I can't see anything that makes me worry about it. And if it flies well, that is the acid test. Enjoy!!
Yeh, I saw that.
That is pretty normal.
For 4s I would use
MOT_THST_BAT_MAX 16.8
MOT_THST_BAT_MIN 14
MOT_THST_EXPO 0.65
MOT_THST_MAX 0.95
You will probably need to auto tune again after changing these parameters though.
Hi Pomaroli, this is just for the throttle curve. It doesn't effect flight time or battery fail-safe.
Hello SwissFreek,
I'm not completely sure what the issue is, but I noticed the same thing back in 3.3-rc5. It has something to do with ATC_ACCEL_Y_MAX. leonardthall reviewed my log and found this setting to be at 9000 and suggested setting it to 27000. That did the trick. (the discussion was back on page 107) I recently settled on 40000 and the yaw is very crisp to my liking.
But there is still a problem as when you run a Yaw autontune, it will default back to 9000. You'll have to go in enter the value you like.
RTL via GCS in 3.3 RC7
When finished auto-mission with the copter hovering at the last waypoint I can´t switch to RTL via GCS (Tower) - i have to use the RC.
I´m quite sure it has been possible in 3.2.1 and in the first RCs of 3.3 even with flightmode auto still switched on on the RC.
Also after finishing the auto-mission gimbal control with RC channel is switched off - i use it to turn the lens of the camera upwards to protect it from damage during land.
Is this the correct behaviour or is it a bug? - providing logs is only possible via cloud because of size so I have to upload the .bin to dropbox what takes about an hour or two with my slow connection.
As I received all replacement parts after the rc6 crash I did a few runs today with rc7. No rc6 problem (but it happened only during the 3rd battery last time) so fingers crossed.
Generally very smooth experience with some comments:
- with strong wind loiter position hold was very nice; however position hold mode correction was absolutely different - very twitchy and nervous;(my PID from rc6 tuning)
- switching from loiter to pos hold resulted in climb ... it was my feeling/POV but could not find it in the logs
- I had the strange feeling that in loiter I could manage the quad orientation in FPV very well, but in position hold it arrived siding or even with wrong yaw.
logs
video log1
video log3
Furthermore - minimOSD/mavlink info so strange ("disarmed"; speed info etc.) that dont even check on the 2nd video.
Video of my small electric helicopter flying AC3.3 RC7:
Impressive ,somersault in the air is what model to fly?
Roll and lateral roll back, the flight manual, or Flip mode?
Pixhawk can provide some parameters Sab380 it? Compare my 500, to make a comparison.
The flips and rolls are all done in Acro mode. I've never used Flip on a helicopter, and don't recommend it.
I'll try to attach my param file on the helicopter thread.
287
288
289
290
291
of 449 Next
