Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Has anyone else had trouble geotagging gopro pics via mission planner with 3.3rc8? Works well with 3.2 for me. When I tried with 3.3, using time offset, est offset always shows -1, then pre processing finds no matches. 3.3rc8 log below.
    2015-07-30 16-45-21.bin
  • Randy, maybe it will appeal to you to compile something like 3.2.2 with most of the 3.3's non flight control related features like different gimbal serial  support, retracts and some other kinks? I think it is beneficial for both the AC project and us is users as we'll get some useful features on a hell of a stable platform, while you guys will get a chance to iron out any bugs in the said non flight control related features at the same time you will get some more time to work on the EKF and make 3.3 something really great instead.
  • This reply was deleted.
      Yes, that just means that the baro thinks it's below the home altitude.  The baro suffers from drift (a natural consequence of the type of sensor) so it's possible to see negative numbers even when it's not below the home altitude.
      This looks like a very sudden drop, I can't see the logs but I'd guess that it's an aerodynamic effect caused by the vehicle moving.
    • 2+ years ago when we first saw a dude turn his dead cat into a quad most of us were appalled, but it started a whole genra of frames and frame conversions. Whilst I find it in poor taste I don't find it any more odd then someone taking their dead pet to a taxidermist.
    • People (governments) are using drones to slaughter entire villages, so the cat thing is really nothing..  God and Drones have nothing to do w/ each other.  (I wouldn't do that to my dead pet, but there are all sorts of people in this world!)
      (And, this is more of a technical info forum.. Go to rcgroups drone section for random chit-chat)
  • I noticed with RC8 that after a while a get a fast flashing green light which would indicate low hdop I'm assuming.
    I also found it a pain when scripting a number of missions that I needed to constantly switch flight modes because the copter would not arm in Auto Mode.  I was using Tower to quickly load different flight plans and just needed to have them run only to have to walk over to my RC transmitter and flip the switch so it would not be in Auto Mode.  I could have pushed a button on the tablet I suppose but it seem faster to flip a switch.
    Mike
      • I know but it would be nice if your just using a GCS and what to fly a number of missions that at the end of the mission it would switch back to Loiter or Stabilize once it lands so I can just lock and load.
          Yes, the the fast flashing green LED is a good thing.  It means the GPS has SBAS so it's precision should be better.  We will definitely add this to the LED description wiki page before the official release.  Sorry for missing this in the release notes.
          Yes, not allowing arming in Auto and not switching out of AUTO at the end of a mission are safety features to stop accidental takeoffs and to reduce accidents caused by the pilot not knowing what flight mode the vehicle is in.
  • I tried rc8 on my 250 size quad. Althold, poshold, loiter, rtl is ok. and also I have tried flip, everything looks good in my opinion
    Only flip mode needs fine tuning on my 250 size quad
