Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
They are unless you remove the RX pin from the GPS lead
Paul,
Ok, thanks for that report. I think what must be happening is the GPS must be restarting and the standard config for the compass is not to send the new hdop message. One way to fix it would be to connect to the GPS using u-center and default that message to on. A better solution would be for us to add support in the driver to set this message on if we find it's not appearing.
I realized a very bad autotune with both rc7 and rc8.
Hi Pritam,
That is definitely a terrible tune on pitch!!!
Do you have a log?
I would suggest resetting your pitch parameters and redoing the pitch tune. You may need to increase the aggr to 0.1 for pitch. You can do just the pitch by setting the Autotune_axis to 2.
Sorry for the slow reply!!
I've had the same thing, low pitch stab and PID values from rc7/rc8 autotunes. Your PIDs don't look to bad, you could try increase the stabilize and see if it's better? Also your IMAX numbers are low, I think these were increased significantly in recent RCs.
Pritam,
If you have a look from when the AutoTune was performed Leonard can probably take a look.
3CityDrones,
The problem is probably caused by very high vibrations. Below is the output of the VIBE message which shows the vibrations are up above 50m/s/s and clipping of the accelerometers is also happening. So not sure what vibration isolation system you're using but I'd recommend the 3M foam. Feel free to post a picture of how your flight controller is mounted.
3citydrones,
The VIBE message is pretty definitive about the amount of vibration. I'm not necessarily saying it's the only cause of the EKF-Check errors but the vibrations are very serious it would be best to resolve that issue first. The levels are about 3x what my IRIS produces and in the same range as the Evgeny logs in which the vehicle lost attitude control.
We are working on improved vibration resistance for -rc9 but in any case, these vibes are pretty serious and should be taken care of.
BTW, had another crash copter on 3.3-RC8. It's Pixhack too.
It's quad V-tail. Fly good in stab and Althold but after few minutes its made crazy and go to ground in angle ~45 rgad.
Log in attach. I think this because high vibration too.
Still wait for RC9
2015-08-03 17-47-11.bin
Yes, extremely, extremely high vibrations on that one.
238
239
240
241
242
of 449 Next
