Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Hi Randy,
            I have set mot_thr_mix_max to 0.9 and tried again. same result. I have added log for my last small try. I will try to find the problem in log file
            1.zip
              Hi Alp,
              It might be worth trying
              INS_GYRO_FILTER,40
              RATE_PIT_FILT_HZ,40
              RATE_RLL_FILT_HZ,40
              That may have been the problem. I can clearly see your roll being the dominant cause but your pids shouldn't really cause it unless you have changed your cell count or esc settings.
              • I will try these settings Leonard and i will inform you about that.
                by the way there is no problem on my cell count and esc settings with rc8. rc8 was realy cool works with my hardware.
                that.by | Ещё один сайт на WordPress
        • I installed rc9 on my 250 quad, and it fly's great.
          So, it's not an issue on all 250 size frames.
  • What may be the reason I do not see Emergency Stop in Ch7 nro Ch8 options? I use 3.3 RC9 and newest (non-beta) Missionplanner.
  • quickly: had a few flights with rc9 on the tri and they went quite nicely and smoothly. No adjustments needed whatsoever. Is there anything tricopter-specific you would like me to try, then report back with logs?
    • Will be loading rc9 on my basher tomorrow morning and flying afternoon. Did you have to adjust yaw pid?
  • Question about the landing gear.
    When does the landing gear retract and when does it deploy when set to auto?
    Currently when I take off, I have to manually retract it by flipping the switch, then I set it to auto and I see it deploy when it lands or when RTL activates. I haven't seen it auto retract, is there a certain height that it retracts?
