Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi
Besides what has been said by Trent Russell there's something very strange on your vibration log that occurs right after you said you changed to PosHold. If you see the clipping that jumps at that time, I would say that something physical came loose and from that point forward the copter was trying really hard to keep up.
I know that now might be almost impossible to trace back where the physical fault might have occurred but look carefully at what might not be crash results.
Hi! This is a question specially for Leonard and I think and the answer might be a good addition to the Wiki.
Let say I have a copter that I know the PID should start at 10 for stabilize Pitch and Roll and 0.25 for Rate Pitch and Roll. I remember that those values are near the previous ones that I had on the same copter but I had to clear the eeprom and I forgot to back up :-(.
Does it help and speed up the process if I start with that?
Maybe this can be extended to a second autotune if the values that are setted in a previus one are not too accurate?
Thanks so much for the help
Hi Bernardo,
Yes you can manually add those values and Autotune will start there. It will also speed the process up considerably. That is why a second Autotune will run significantly quicker than the first.
The main reason I run a second autotune after I successfully finish my first is because poor tune on one axis can mess with the results of the other axis a little. The second Autotune runs relatively quickly (I always wait for good conditions for the second tune) and gives me confidence I have close to the optimal result.
This is great info! I did not thought about the second autotune right after the first one but is a logical thing.
I know the default PIDs are really conservative (or maybe they are thought for small overpowered copters) but I have a large octa and even though it flies at 30% throttle, I have to almost double the original ones.
Please consider adding this info in the wiki. Many people like me sometimes makes a clean install on a copter and we almost know what values are optimal and we need autotune to polish the numbers.
Thanks for your great work
Leonard, you refer to wait for good conditions for the second tune; on your first tune what conditions you choose? . my cuestion is because I wait for calm day to tune, but I need to fly with wind; It's better if I autotune with the same conditions that I want to fly? It's possible to do autotune with windy conditions? Thank's
Hi Cala,
No, it is defiantly NOT better if you autotune in the same conditions you want to fly. I understand your reasoning but Autotune will give you the best results for both windy and calm conditions when tuned in calm conditions.
On my first tune I will still look for the best conditions I can but I will sometimes compromise to get a reasonable starting point. Generally I can find some good conditions, at least once a week, early in the morning or in the evening where I live.
Thank's Leonard, I'm going to try the double autotune, nice tip.
I must say my initial tests with 3.3-rc10 running totally stock everything on my beater quad with a Hawk Lite is one of the better firmware revisions I have run in a really long time. Rock solid. Alt-Hold is working well, Loiter is back to being like it is hanging from a string and RTL worked flawlessly each time I used it. Awesome work!
Use X and it should be front left motor goes clockwise then front right goes counter clockwise then rear right goes clockwise and rear left goes counter clockwise and are ordered as it shows Starting front left and going clockwise around the frame 3-1-4-2
Hi VP,
Not sure what you mean about the bitmask, I recommend using 157693.
You are correct about the axis numbers.
186
187
188
189
190
of 449 Next
