Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
A bit of a question here: has the way RSSI being reported in the mavlink been changed in 3.3? I have a strange issue when I setup up my RSSI pin 103 and range 3.3v MP shows correct rxRSSI, however minimosd shows constantly 0. I roll back to 3.2.1 and I get RSSI back, while with exactly the same settings RSSI is 0 in the minimosd while correct value in MP. Please advise.
Hi ,
The “ping-pong” between 2 GPSs is old (not a rc10 issue) ..... I don’t have the logs anymore, but from August I removed the second GPS from my Quadcopters…. The Crash is really difficult to happen, but happen in different conditions.
http://diydrones.com/forum/topics/copter-3-3-beta-testing?commentId=705844%3AComment%3A2068761
Greg,
We won't fix the dual GPS issue in AC3.3 I'm afraid. That will be an AC3.4 improvement. I'm going to change the wiki to say that we don't recommend a dual GPS solution for copters until this enhancement is in.
no idea sorry.
We are on page 279 of feedback and at release candidate 10 to a new Arducopter release and no end, meaning Release, is in sight.
I must say that I lost track in the meantime.
Is it because the code got completely rewritten and along this screwed up?
Or is the reason that the requirements and expectations are raising from RC to RC?
Randy , by when do you expect a halfway stable baseline across MP, Arducopter, and Tower with existing documentation in the Wiki?
Again, I don't want to discredit all the important discussions going on here, but if it continues like over the past months I am afraid that we rather hit page count 1000 and RC 50 before anything meaningful emerges.
Disclaimer: I am a satisfied user of 3.2.1 and I am desperately waiting for some 3.3 enhancements. And No, I don't have the time to wade through multiple RC's testing.
these threads are always long and hard to sift through if you are looking for something specific, but that applies to all forum/blog type discussions. I personally don't think the release cycle is that long given how many new features are implemented. Also compare to some other open source projects which normally are a right mess of code and bugs. In this regard APMcopter has come a long way in the last two years. If you don't want to risk testing betas, stick with the old stable version and wait. I found, especially with 3.2 and 3.3, that I could fly all release candidates without being overly afraid of bad things happening which was not always the case in the past. So I think the dev team is doing a really great job here!
Stephan,
Glad you are happy with 3.2.1! Do you know or appreciate why you are so happy with 3.2.1? It's because of this exhaustive process of beta testing. Lets refresh our memories. Work on 3.2 beta began with the first release candidate on May 9, 2014 (actually work began long before that with the dev release), followed by a series of 14 release candidates until its "stable" release sometime in November, 2014. A few quick enhancements and bug fixes were tested and released by February, 2015. So that's May-2014 to February-2015 (10 months) to give you the "stable" release you are so happy with.
Now lets talk about the current beta cycle; The first beta release candidate was presented for beta testing in April of this year and is currently on RC10. By all accounts it's quite good (at least for me).
Patience is the key here. If you don't want to follow the 279 page thread that's OK, but don't complain about how long the process takes to bring you a "stable" product you can use with any degree of confidence.
I agree that these threads can get extremely long. But if they were only filled with on topic discussion they would be much shorter.
Enjoy 3.2.1 while you wait.
Nathaniel ~KD2DEY
appreciate your reply and I truly respect all the good work of the developers and beta testers to create a high quality product.
Please allow me to raise one observation after following this thread over the past months. In my view the software got too complex in the meantime, the increasing number of copter config options and to be supported 3rd party devices and clones is compromising speed of innovation.
In my view 3DR made the right decision to split the Arucopter code for Solo, otherwise this great product would have missed the market opportunity.
So I shut up here and put my Pixhawk project on hold and patiently wait for the release.
In the meantime I enjoy my new Solo :-)
Best Stephan
This is how opensource software works. Multiple developers and the users can choose to be part of the beta testing, or, wait for stable releases.
Complaining about the development cycle time when the developers and community are working very hard to implement many new features and ensure it all works with multiple GCS's, multiple hardware types, multiple sensors, all from different manufacturers is crazy.
If you don't want to help with development or testing and only want a finished product, then don't complain about the time and effort others are putting into it.
I can confirm that Auto Take off with Tower software no longer works. It switches to Auto mode and says it's flying to waypoint 1 but never leaves the ground and disarms itself. This worked in 3.3 RC 9.
176
177
178
179
180
of 449 Next
