Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Hi. This is a question for the developers but I´m not sure it is a 3.3 only thing.
    I have a big octa which has an extra battery for the gimbal and the pixhawk conected to an output so when I deplete the main one after flying, I can put a new one and I do not have to wait for everything to settle. The thing is that if the copter reaches failsafe voltage, it does everything that is supposed to (RTL) but once it lands, I can not fly again because the failsafe is not cleared even though the voltage is a 25.1
    Is there anything I can do? Or is it a software bug?
    • I have tried to the same thing with a backup battery on the 5v rail. I was hoping to be able to "warm up" the GPS on the way to the field and do hot battery swaps. So far I have found that I still have to fully power down in between battery cycles.
      It would be nice to have some way to warm up a multi with out having to have the main battery connected.
      This feature would be valuable to any emergency services use where rapid deployment is needed.
      cycles.it
      This domain may be for sale!
      • Exactly. Another use is taking off from a boat. I need to start the apm on the shore to make the gyro cal and them move it.
  • Just had a crash...  I'm not sure what happened, but it wasn't good.
    Let me try to explain a bit.  I have a quad, quite vanilla in design about 14in  MTM. Been flying it for about a year, its a good flyer. I have been flying the beta flightware (updating as each rc was released.) mostly just low level flights around the yard. I had 4 un-eventful flights on rc11 flightware in and out of alt hold and loiter modes many times.
    Today I decided to try a simple programmed mission and fly it from my android tablet, with the xmitter on and standing by.
    The Mission;
      Auto takoff, climp out to 250ft, loiter circle 2 times, decend to 40ft hold for 20sec. autoland.
    I armed the bird from the tablet, OK,
    commanded the auto takeoff from the tablet, OK.
    commanded it to auto mode from the tablet, OK.
    All went well up to the final landing sequence. At this point (I think) it got below the tree line  lost some of the lower gps satlites and started to drift into a tree.
    This is where things went bad....
    From the transmitter (not the tablet)  I switched to Altitude hold, this caused the throttle to drop to idle and it dropped about 10ft. to the asphalt,  Splat......
    I was recording the GS video of the Heads-up display onboard, and looking, it clearly shows DISARMED in the display while it still flying.
    Question....
       Is there any cross checking between commands sent from a tablet and commands sent by the transmitter?
       can it be armed by the tablet and still think it's disarmed?
       Or did I do something I should not do. Mix tablet control and Xmitter control?
       Or worse.. Did I find a bug?
    I will try to re-create the error condition again. ASAP.
    Flash log file; 63.bin
    Thanks for looking at this. and Thanks for any and all input/comments.
    Mike
    63.BIN
  • With rc11 I am not getting Land and RTL reported by the GCS when I am still on the ground. This happens in both MP and APM Planner. The modes work and I believe they are being reported when flying, just not before arming.
  • I'm trying to autotune a QAV250 on rc11 and I physically can't do it even though I'm doing one axis at a time. I'm using a 1.8Ah lipo which gives about 6mins flight time and each axis takes longer than this. I just about managed yaw, but pitch was still going when I hit the battery failsafe. Any suggestions? I can't use a bigger battery - it's already pretty big for this size of craft. Surely there should be a way of limiting the autotune time? Anyone have some reasonable numbers for a QAV250 that I could use as a starting point?
      Hi Andy,
      If you do one axis and post it here I can tell you where it got to before you had to come down. That should make it faster for you.
      The most important parameters to change for smaller quads is the filter frequencies:
      RATE_RLL_FILT_HZ, RATE_PIT_FILT_HZ, INS_GYRO_FILTER
      Set them all to 40.
      I have done a write up on setting up smaller copters here:
      http://diydrones.com/profiles/blogs/fpv-racing-using-arducopter
      • Thanks Leonard. I have now worked through your post in detail and will try again when the weather permits it.
        Roll is:
        P: 0.425
        I: 0.425
        D: 0.04
        IMAX: 200
        Stab RP: 3.469
        Pitch didn't complete so I assume it didn't capture any values?
        • HI Leonard,
          I tried again today with all the setup you mention and still cannot get pitch to complete. My flight time is about 7mins but that still isn't long enough. Part of the problem is that the vehicle is very light and agile so any wind will move it quite a lot (my bigger quad has a lot of inertia so does not move nearly so far or so fast). There's not much wind today but its still too much to simply leave it to get on with it and I keep having to bring the vehicle back. Hoping for zero wind at this time of year is unlikely.
          Any suggestions? Is there any way to capture intermediate results on a single axis?
          andy
            Hi Andy,
            I can look at your logs and give you a better starting point if you like.
