Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Make sure you have your compass orientation set properly. At some point in AC releasese devs changed default compass orientations, so what it usd to be roll_180 now is orientation_none.
        • With good calibration I cannot get it above 0.5 even when turning it quickly. If it happens when you turn it slowly then something is up - either calibration or local interference. Hard iron and computers are bad - but you only have to be a meter away or so for this not to matter much.
          What FC do you have, have you run compass mot?
        • Are you doing this indoors anywhere near say a PC or speakers or anything else large and metallic?
          Does it do so outside when you're not around anything such as a car or anything else metallic?
          • It does it when I'm up in the air, so it's not a metal object causing it.
            I have done a compass mot, and I have recalibrated several times.
            It's an auav-x2, with external gps/compass (currently, csgshop).
            But, sounds like others aren't having the same issue.  So like I said, I'll stop talking about it here in the beta section.
            I probably just need to drive somewhere else to calibrate..  Every room in my house has speakers. (I build hi-fi amps as another hobby.)  My yard has metal sheds and porches.  Mostly aluminum, but some iron poles.
            Sounds like these could be causing some calibration issues.
            Thanks Andy and Craig.
            • Make sure you don't have the problem I had - AUAV-X2 + ACPS3 give spurious current readings when the battery is not connected. This means that the MOT offsets will be applied even though there is no interference - leading to a very unhappy EKF when on USB power. Try setting COMPASS_MOTCT to 0 just to check.
  • Hi,
    I have a problem with the beta firmware on a VR μBrain 5.1
    when I try to put the new firmware 3.3-rc12 on the VR μBrain it shows in mission planer as 3.3-rc8.
    Anyone else with a VR μBrain come across this ?
  • I have tried 3.4 dev (master) and i have problems with compass calibration on Raspilot v1.1
    i have a external compass connected as well as the internal (s).
    Anyone else using Raspilot ?
  • I don't know if this is a Pixhawk problem or build problem but I can not get an acceptable compass calibration. I have done just about every method even spinning in an office chair. At the end of 20 minutes of spinning and 1700 data points I still end up with compass 1 with -931 613 -2655536 and compass 2  314 -195 -44 After restart I still have a double flashing yellow on the pixhawk, error compass variance in MP and a red EKF for compass on the HUD. This is with RC12 and the latest version of Mission Planner on a 2104 3DR quad frame and PDB with a M8N GPS/Compass from Ebay on a 6in extender.
    Any suggestions or will have have to keep playing spin the chair with my son? He for one enjoys it.
    • Spinning in an office chair should be avoided because its steel and had disturbes the field. You should do it outside away from large steel objects(cars). Having said that, the numbers indicate that mag 1 has failed or has a huge interference. Try disabling it.
      • Oh boy that would suck if the internal compass was on the fritz. I'm sure that's not an easy fix. I tried the MAG_ENABLE option in Mission Planner and it disabled both the internal and external it appears. I couldn't get over 3 samples with it on and once turned off it would at least give points.
