Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks Richard- totally understandable and I do see this behavior with my acro quad. If you tilt, you must throttle too :D.
I was thinking that if poshold incorporates automated altitude correction, it would sense the drop in alt during forward flight and apply more throttle as needed to compensate. I do have ahrs_gps_gain set to 1, was thinking there might be a P gain like "POS_Z_P" that is related to determining the aggressiveness of altitude hold in forward tilted flight. again this is only really noticeable or significant if flying into a headwind, or if in a set position hold and copter is battling a bit of headwind from any direction. copter will compensate and tend to drop in alt. if it is no longer busy compensating it will regain height. however if it keeps compensating there is chance it will work its way to the ground.
but, i did not see it drop alt too much during set position holds - as a matter of fact, it was downright impressive :D. it only did that a couple of times. it does it very consistently with alt drop on forward tilted flight though, into the wind.
http://diydrones.com/m/discussion?id=705844%3ATopic%3A2071704
thanks - "up to speed" - no pun intended right? ;p
I had read that some time ago- i have this exact setup with the RC timer flight platform and dome, per Leonard's findings: "Based on what I have seen so far the best approach is to sit the pixhawk on a nearly solid plate with minimal holes in it. Then cover it with a dome of some sort, leaving only a small gap around the edge. This should then minimize altitude variations caused by attitude and speed."
during stabilize mode forward flight, or drift mode, there is no issue beyond "normal" with alt drop and simply needing to maintain throttle as needed. I am talking specifically about the automated PosHold mode, which attempts to correct both position and height. it is in this mode that the alt drop on tilted flight, into the wind, is pronounced. it is hard to compensate throttle manually since there is an imposed deadband around throttle mid stick.
Does it have this problem in forward flight in alt hold or only pos hold?
Richard- I want to say it does do it a bit in althold mode as well. i did not fly althold mode around as much as position hold, but i did notice some drop into the wind as well in althold- just not as pronounced as with poshold. direction did not matter either, it would do same drop off whether forward pitch 15 degrees into wind or say roll right 15 degrees into the wind, and hold that for say 25 yards sustained. it was a gradual and consistent decline in alt. if i let go of sticks it would auto brake, then eventually pop back up to the last alt. a few times it did not pop back up though.
also, it was harder to apply some manual throttle to compensate in poshold mode vs althold mode.
on that note I was also asking if you guys typically stick with the associated 100 deadband default or slim it down to say 50.
keep in mind I consider this to be fairly minor- i am only bringing it up in case it is worth looking into.
I assume this has already been discussed but, for the life of me, I haven't been able to find a way to search this forum's database.
I just completed an auto tune of roll and pitch. The results between roll and pitch are completely different, ie:
Roll Pitch
P 0.2312426 0.4205088
I 0.2312426 0.4205088
D 0.00845350 0.01838647
Would someone please advise whether or not this is normal, or should I be concerned?
I'm flying a Pixhawk with 3.3 RC-12 on a Tarot FX690Pro (hex) with 3805-580 motors.
Thanks for the replies...
Hi Tom,
Yes, both roll and pitch should be different on a hex. Yours are very different but if your copter is flying without issue then you are fine.
On my 680mm frame the roll axis does not have to fight the weight of the battery or gimbal as the weight is along the roll axis. On the pitch axis these heavy components move a lot.
Hello,
i've updated to RC 12, basically it works pretty fine. i have only two suggestions :
1. Something has changed for the Battery Failsafe from AC 3.2 to AC 3.3. On AC 3.2 the Battery Failsafe was reset by disarming the vehicle which was pretty fine. For AC 3.3 i have to disconnect Battery to reset Battery Failsafe. Can this be changed back ?
2. The Autotuned PID For YAW axis seems to be about 15% to high. This occurs when the PID are already adjusted by a previous Autotune run and we try to recalibrate. Generally i have the impression that the PID are a little bit to high and the ATC Accel Yaw to low. Probably the Result could be better by lower PID and higher ATC Accel Yaw.
And another question, how does ACRO_YAW_P influence the ATC ACCEL ?
