Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
vibration levels abit high but there was a 23mph gust winds
vibration within normal levels on not so windy days
stu
sorry missread where you said you covered the entire hawk in cling wrap and not just the baro :(
you should NEVER cover the holes on the baro. Use dense foam not cling wrap.
Stuart
What Craig is getting at is that you said you cover the whole pixhawk in cling film, which is essentially the same as covering the holes on the barometer rendering it useless.
I still got height reading on mission planer
Cheers stuart
I have done about a dozen flights now with V3.3 on my littlest Pix, a 320_mm hexacopter. I had a few issues with the Autotune and PIDs on upgrade, but this thread has helped me sort those out. Thanks boyz. I have been pretty satisfied with V3.3
But, today I have landing gear and a bent arm to repair. On my last flight, it inexplicably dropped from the sky. I have tried to decipher the cause from my logs, but I don't have the experience to determine the issue. It felt like a voltage drop, but the battery had over 11_V remaining and the cells are within .1_V of each other.
Can anybody suggest the culprit? . . .
2015-11-06 17-21-17.log
I'm still learning how to interpret 3.3 data, but:
Vibration is very bad.
Is there a power module connected?
Battery levels aren't logged
Current not logged.
Mag levels out of the ballpark.
No Mag offsets.
EKF must have been doing somersaults.
Upgrading AC from 3.2.1 to 3.3 caused PIDs confusion.
I've never changed PID values for my PixHawk based quadcopter before. I always used the default values, and it flew perfectly. But one day after upgrading the firmware to AC3.3 (I did all necessary sensors re-calibration) my quad started flying very wobbly. It was harshly oscillating in any flight mode, especially when I let it just hover and do not touch a controller. It was twitching instead of being calm. I've never faced anything like that before... Sample video: https://youtu.be/FBSDrych4wo
I realised that it's a PID related issue and I decided to run AutoTune - I thought it's the easiest way to sort it out. After facing a crash during the AutoTune session (gps stick + arm were broken) I understood that it won't be so easy. Video: https://youtu.be/NfqnJZm1NsQ
I've gone through the Arducopter wiki and some other tutorials on Youtube, and tried to tune PIDs manually.
At first it was rather successful - I decreased Rate P value a bit (from 0.150 to 0.126) and those crazy oscillations went away.
Then I've faced the same issue that I had during AutoTune session:
1. I move roll/pitch stick in one direction
2. The quad gets some horizontal speed
3. Then I harshly move the stick in opposite direction (for emergency breaking or to instantly change the flight direction to the opposite one)
4. The quad tilts in that direction and starts resisting the speed and attitude (what is absolutely expected)
5. Then it suddenly kind of flies off the handle... and does a half-flip/flip of death with rotation around the vertical axis
Please see the video, which demonstrates several flips like that: https://youtu.be/jq_N8E_c4M4 (could provide log files if needed)
I tried to increase Rate I value (from 0.100 to 0.150) to solve the issue. At first it seemed to help. I got rid of the flips at a low speed, but when the quad speeded up significantly it appeared again.
Unfortunately, I didn't manage to play with Rate D, because of the broken GPS mast.
Gents, what parameter tuning could help me with the issue described above (flips)? Didn't try Rate D and Stabilize P yet.
Thank you in advance!
My quad details
Frame: custom 350mm V type (not Vtail)
Weight: around 1kg
Motors: SunnySky 2208 1100KV
ESC: Afro Opto 20a
Props: 8045 plastic
Battery: 4S 3300mah
FC: Pixhawk installed on a dampered plate
