Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Nice flying field!!!! I wish!!!!!
    • My opinion in your post
  • I have a 2nd 3DR Pixhawk which I test from time to time using the GPS on serial port 2 as the original gps port got ripped off on a flip over.  I tried a few flights on v3.2 and it worked, but didn't feel comfortable enough to fly it that way so took it off.
    I've put this crippled Pixhawk on a quad for some more testing this weekend.  I put the latest beta on from today.  I notice my status  says  no gps but if I look at the detailed status in Mission Planner, I see the # of sats and hdop data.
    Is there anything new in any of the versions that might be relative to what I'm trying to do to help make this somewhat reliable using the sat connection into the serial port?  Will tower show the # of sats and hdop?
    Sorry for the simple questions, but have been away while and have decided to put my good Pixhawk on an 20 lb x8 if I can get over some of my calibration problems.... Just thought I'd reacquaint myself with the lastest firmware and a less expensive lighter quad first.
    Thanks in advance for any advice.  Hope it's ok to post this here.
  • hi Randy , my apm hexa is take off with 15-25% thorttle and hover with 20% thorttle. really hard to control and land. can you help me how do i fix it ? i'm flying hexa size 900. motor 380kv sunnysky. props 15.5 tarot, esc 40a hobbywing. battery 6s 5500 genace.
    thanks you so much!
      TriTran,
          The short answer is probably to add extra batteries to the vehicle to increase it's weight so that it's hover throttle is at least 30%, then reduce THR_MIN if possible (it must always be high enough to keep the motors running even when the battery is low) and accurately set the THR_MID to whatever the CTUN.ThrOut values shows.
          I think this is a better solution than trying to keep the hover throttle at only 20% because the THR_MID value is limited to 30% ~ 70% and having it not match the vehicle will lead to various problems with the transition from manual to auto flight modes, the landing detector and pilot throttle feedback when landed in modes like AltHold and Loiter.  Also with hover at only 20% the attitude and position controllers don't have much room to work with.  In some ways it's similar to trying to control a vehicle with a very low battery (i.e. hover throttle of 90%) - vehicles with low batteries also don't perform well because they hit their (upper) limits.
      • Randy
        yes i agree. i leave all by default, it's diffrent so much with my hex f550. i don't know why i take off with f550 with must over 50% throttle. but with hex s900 then only 20-30% is take off, really hard to control and landing, really easy crash. do you have any tips of your parameter thorttle accel and more ?
        i see in THR_MID is 700, so i need to drop it to 300-500 ? any ideal ?
        thanks you!
        • Add weight! You are way over powered. My T960 is the same, hovers at like 30% so I added some dummy weight to help and it does. Still no where near the proper 50% but at least now setting THR_Mid to about 40% is close and it doesn't skyrocket or fall on flight mode transitions now :)
          • oh thanks you. so i must add add weight, battery or something ? then fly test and take out ? or i put it forever ?
            • I have a photo quad with 390 kV and 15x5 props, and I'm loaded with a 10.000 mAh 6S for 34% hover. And that's with only four motors !
              For your hexa, a 16.000 mAh pack would be fine, probably even a 20.000 mAh.
            • I went from flying with 2 2200 mah 4S to 2 5000mAh 4S and that helped a LOT. I will be buying some 5000(+) 6S soon and then adding my gimbal and stuff should bring it down to my needed 50% :)
              Another thing you could try is smaller props for now. It will not be as efficient and will cut down on flight time, but it would help bring your throttle closer to the golden 50% :)
              or just add some weight. Doesn't really matter what you use really just make sure it doesn't toss off your COG and also keep in mind more weight = less flight time so adding dummy weight will decrees the time you get to fly which is why I elected to use bigger batteries so that I offset the extra weight with more reserves :)
DIY Robocars via Twitter
RT @_JonMyer: 🚨Attention DeepRacer's including #UndergroundDeepRacer🚨 Check our our LIVE stream that including @IAM_dbro Take a few moments…
yesterday
RT @chr1sa: The @DIYRobocars @donkey_car virtual AI car race is starting in 15 minutes! Watch it live on Twitch https://www.twitch.tv/mossmann3333 htt…
Aug 1
RT @chr1sa: Don't miss our monthly @DIYRobocars @donkey_car virtual AI car race tomorrow at 10:00am PT live on Twitch. Head-to-head racing…
Jul 31
RT @sparkfun: Our completed tutorial on building an @NVIDIA Jetson Nano-powered @Sphero RVR gets your bot up and running via teleoperation…
Jul 30
RT @SmallpixelCar: Freeway test https://t.co/4V5tV9lhIP
Jul 29
Very small autonomous cars racing, thanks to an overhead camera: https://control.ee.ethz.ch/research/team-projects/autonomous-rc-car-racing.html
Jul 29
Jul 29
Jul 29
RT @chr1sa: Don't miss our virtual AI car race this Saturday! Real developers + virtual cars =🏎️🏎️🏎️ Head-to-head battles with thrills, sp…
Jul 28
Jul 27
RT @usashirou1: Jetson nano by Isaac Kaya #jetson https://t.co/Mu1N0CyQkN
Jul 23
RT @GPUsolution: JetRacer mady by Iflytek company #JetsonNANO #Nvidia https://t.co/MimTymIwge
Jul 23
RT @openmvcam: I love this: Mega or Mini? Image Classification on the 1MB OpenMV Cam H7 by Ish Ot Jr. in OpenMV, Edge Impulse, Internet of…
Jul 23
RT @RoboticMasters: This is looking pretty good... but still needs a bit more refinement. Pure OpenCV Turning Sign Detection. No Tensorfl…
Jul 23
Jul 23
Jul 20
