Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
What's better, a manufacturer in China using cheap labor and Chinese parts or a manufacturer in Mexico using cheap labor and Chinese parts? Pretty much "six of one or half a dozen of the other"
They are all using the same Schematics and pretty much the same BOMs.
The reason 3DR sells for twice as much is not because it costs them any more to produce than a China plant but because they actually invest some in both customer support and help support ETH Zurich. But I find it hard to yank twice as much of my hard earned cash out of my wallet to buy a Hawk simply because it says 3DR on it.
I'd say 3DR is selling older hardware at twice as much as everyone else.
The log is attached to my message at the start of this chain. Cheers
How do I use bluetooth with serial 4/5? Telem1 works fine. I can connect with APM planner when bluetooth is connected to serial 4/5 but I get no data and the HUD does not update.
I'll answer my own question!
SERIAL4_PROTOCOL = 1
SERIAL4_BAUD = 57
Just updated to MP 1.3.29 and now my throttle and yaw mapping is swapped. Someone in the Rover group noticed this too. Has anyone else in the arducopter group noticed this too....
This was a bug in MP 1.3.29 and is fixed in 1.3.30. I spotted it too and reported it in the MP thread on here and it was picked up by Michael Obourne and sorted quickly.
I can confirm I'm seeing the same behavior but am not sure if it was me upgrading to this firmware or MP.
Need a bit of help with starting parameters. I mean before auto tune of one axis at a time.
After installing 3.3 rc-5 successfully on 2 small quads and 2 medium size hexacopters (1000 mm { 1 meter motor to motor} 7 and 9 Kg {246.918 and 317.466 ounces}
Trying to find right parameters (before auto tune) for a 12 Kg (12,000 grams) {423.288 ounces} H frame (920 x 780 mm) with a pixhawk.
Propellers are T motors 17x5.8
Motors are four 5055 1630 Watts with custom adapters to the propellers.
Perhaps leonardthall could give some recommendations?
Thank you in advance.
Hi Henri,
Sorry for the slow reply. I have tried a couple times but couldn't do it as I only had my phone.
This is the process I use when starting tuning a large copter. First up set these parameters
MOT_THST_BAT_MAX,number of cells x 4.2
MOT_THST_BAT_MIN, number of cells x 3.5
MOT_THST_EXPO,0.75
and
THR_MID,300
Then set the control loop parameters to their defaults.
In stabilize slowly increase your throttle until the copter starts to lift of the ground. Listen for any sign of oscillation and if you hear it be ready to shut down the throttle immediately.
One of the things I find is if you are hovering lower than 30% then you will tend to have trouble with autotune. If you are hovering at a very low throttle position then add weight to get your copter up into the 30% to 40% range. If you are above that then no problems.
Once you can take off safely then you can start testing small roll and pitch inputs. Keep the copter low so you don't do too much damage if you need to shut it down. I will tend to do this at around 0.5 m.
If you find the copter reasonably safe then you can increase height to say 5m and increase the roll and pitch inputs.
If you find the copter is a little wobbly (slow wobbles about as fast as you can say wobble wobble wobble) then increase the Rate D terms (you can use the slider set to go from 0.004 to 0.008). Just make sure you don't increase it to the point you get oscillations.
If you get oscillations then you may have a flexible frame or something like a gimbal that can move. If you are lucky you will be able to just reduce Rate D. I haven't seen anything that oscillates on the stock PID settings.
This should get you flying. Then you can build up your roll and pitch inputs (30 degrees) to the point where you feel comfortable running auto tune. If you don't feel comfortable you may need to do a manual tune before you can run Autotune.
Hope that helps and sorry for the delay!!!!
331
332
333
334
335
of 449 Next
