Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • I can't imagine a memory leak, but I often also have the issue of not being able to connect from Mission Planner if the Pixhawk clone has been running for even a few minutes. It seems really random, but I suspect it's nothing to do with APM, but more likely a USB issue at the laptop end (mine shows problems with both the USB cable and the telem radio module). I however, am running Windows 8.1 inside a VM under VMWare Fusion on my MacBook, which I suspect is the source of my connectivity problems. Sometimes, restarting the pixhawk alone does not resolve my connectivity issue, but I also have to restart mission planner (and occasionally restart windows also to get it working).
    • I don't think so.  I left one on over 24 hours once and it was still running.
        Hi Ian,
        Like Rob I have also left a pixhawk running for 24 hours. I have done one up as a logger for different purposes. All I did is set the standard copter code to log while disarmed.
  • This reply was deleted.
    • Nothing has changed as far as my testing goes, I have been reversing channel 2 on my radio since ER9X on my 9X radio years ago, later with OpenTX on Taranis.
        • I swear I remember reading somebody else had this happen as well... I think it's buried in this 3.3 beta thread.
          • I had to reverse my pitch setting too. Stick forward, -100% stick back +100%.
            • Me to with a Taranis,
              In the radio calibration screen it is not clear which way is pitch forward and which is pitch backwards. A simple label at the top and bottom of the calibration graphic would help to make obvious that a control is reversed before finding out on the test flight.
        • The only other FCs I use are with OpenPilot (Revo, CC3D) and Ch 2 is reversed on them. I suppose the expectation is that this will be noticed in the radio calibration process.
              Ok, I reviewed the RC calibration wiki page and it didn't mention that the green bars should move in the opposite direction to the transmitter's stick for the pitch channel so I've fixed that.
              Thanks for pointing this out.
              • related??--- The last time [ 2 years ago ] I set up a plane [ gas ] on a pixhawk I literally had to install and electronic servo reverser to get the GCS throttle [ ch 3 ] display to read high pwm on high throttle and low on low throttle so that throttle FS would work. I think it was an issue that the ch 3 reverse button in APMP2 would reverse the servo but should not have also reversed the ch 3 pwm display… or something like that. Reversing it on the TX didn’t work right either. I spent 3 days messing with it I couldn't believe I actually was gonna need a physical servo reverser but it did. Bottom line I think sometimes when you actually have a servo there are times you need to reverse the throw but NOT the pwm direction shown / read in the GCS and pixhawk.
