Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Kurt,
      Quite often you can reduce the Z axis vibration level by reducing the amount of bell play in your motor housing. As your props load and unload in flight the changing load on your motor causes the housing to jump up and down within the "play" on the shaft. You can reduce this by using a special clamp to compress the housing on the shaft, reducing the amount of excess bell play. The more bell play the greater the vibration as the housing jumps back and forth between the limits. The trick is eliminating the excess without inducing friction or drag on the motor.
      Myself and others have seen dramatic reductions in Z axis vibration by eliminating this excess bell play.
      Nathaniel ~KD2DEY
      • This reply was deleted.
        • Home made...
          https://storage.ning.com/topology/rest/1.0/file/get/3702800471?profile=original
          Kurt,
          I can't take credit for the idea, someone here led me to the same information, paying it forward as they say! If you can't feel any additional end play, then it probably isn't a major contributor. Still worth looking at, but not likely to help a lot unless you can feel some end play.
          As far as what the clamp looks like, it's fairly simple and from what I've seen, usually home made. The basic construction is usually a section of square steel tubing large enough to encompass the motor. A hole is drilled and tapped in the top center and a bolt is threaded in that location such that when a motor is inserted the bolt can press on the shaft. Opposite the bolt a clearance hole is drilled for the end of the shaft on the other side. There is usually a grub screw on the bell that secures the bell to the shaft. Once this is loosened you can compress the shaft and the bell housing together.
          I'm not sure where the original thread is but I'll look around and see if I can find it. I think it was Leonard who originally posted the fix in this thread.
          Yes, Arms flexing could definitely cause Z axis vibrations.
          Nathaniel ~KD2DEY
    • That is the acceleration in the vertical axis.
      You might see spikes when you bump the ground?
  • Hello all,
    A crash apear on my octocopter but I don't understand why...
    I have see the log but I'm not an expert of log review and I can't define the source of the crash.
    (The log notify a first crash but it's just an error of me on the take off the real crash is the second one.)
    Version is AC3.3rc12.
    Thank you in advance.
    I hope my experience will also help other people.
    74.BIN
      Hi Ruchat,
      You have a massive motor output mismatch. It looks like motor 4 is struggling.
      Sorry to hear about your crash!!
      3702598775?profile=original
      • Hello,
        Thank you for your analyis I will check my motor 4.
        Have a nice day.
      • Sorry my ignorance, How do you detect that motor 4 is the problem there?
          Hi Cala,
          I am plotting RC out there and in a steady hover the lines should be pretty much on top of each other.
          I can see Ch 4 is a problem because it is much higher than any of the others. You can also get similar problems if your arms are twisted.
